Bridgestone Potenza S-03 Pole Position VS. Bridgestone Potenza S-02
I'm picking up a 2000 Silver S2000 this Tuesday. The stock Potenza S-02s are shot on the rear. The previous owner tried both S-03, and the stock S-02s, and liked the S-02s better. I had the S-03s on my Integra Type R and they were amazing both wet and dry. It rains a lot where I live so I'd like good wet traction also. The S2k will be daily driven, just like my Integra. I have only driven an S2k in dry summer weather so far.
Anyone tried both in an area that gets a decent amount of rain?
I'll be buying one or the other so any help is appreciated.
s03's slightly better in snow. and like bagel said, make sure you get the 245/45/16 size for the rear
I know why to go with 245 from the 225 but don't understand the numbers. The s-02 in 225 is rated with a 9.2" section width and 8.5" tread width. The overall diameter is 24.8". Now the S-03 245 is 9.6" section and 9.1" tread width. The overall diameter is 24.6". Now if I go with the 225 in the S-03 it is 9.3" and 8.3". The overall diameter is 24.9". The story goes that the S-02's have a better contact patch than the S-03's but I don't see it tire for tire. 0.2 is not anything to frown at. I can see the advantage of going with a wider tire in the back but can't see any other benefit. Input??? What am I missing?
-Chris
Modified by frxtc@9k at 3:26 PM 7/28/2005
-Chris
stock s02 rear is 225/50/16
s03 size you should get is 245/45/16
if hold them side by side, they are the same size. our stock s02's are actually wider than any 225 out there. they are 245 is you measure them. so anytime you change to another tire model or brand, you must go with 245
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant »</TD></TR><TR><TD CLASS="quote">stock s02 rear is 225/50/16
if hold them side by side, they are the same size. our stock s02's are actually wider than any 225 out there. they are 245 is you measure them. so anytime you change to another tire model or brand, you must go with 245</TD></TR></TABLE>
When I measured the tread between the S-02's and my new Ra-1's it was only .15 difference in contact patch. The numbers to buy a 245 to keep the offset between front and rear still don't add up. Help me out here. What the hell am I missing. If it was like .5" then it would be a big deal but .15" ro .2" is nothing at all.
Are they just posting the wrong info on the sizing charts for tread width??
Thanks
-Chris
Thanks
-Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frxtc@9k »</TD></TR><TR><TD CLASS="quote">225.</TD></TR></TABLE>
That's what I run up front with RA1's. A bit too narrow for the rear. But the RA1's are quite blocky.
I can tell by driving behind someone at 100 feet if they have the wrong tires on the back. The stance is just narrow and yes, you will not have as much grip in the rear. Less grip in the rear will be less understeer, which means, more oversteer. Not a lot, but enough to matter to most.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Bagel »</TD></TR><TR><TD CLASS="quote">
I can tell by driving behind someone at 100 feet if they have the wrong tires on the back. The stance is just narrow and yes, you will not have as much grip in the rear. Less grip in the rear will be less understeer, which means, more oversteer. Not a lot, but enough to matter to most.</TD></TR></TABLE>
very true. less grip in corners usually means slower and also more chance of spinning out
hmmm,
I haven't ever spun out and I have pushed the car quite hard. I measures only a .15 difference from my previous tires. I am going to call Toyo today and ask for tread width. They don't have it listed and I don't have my car right now to confirm. It does look like there is a difference in the S-02's used on our cars and the replacement pole position. Tread width is different.
Thanks for the info.
Chris
Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frxtc@9k »</TD></TR><TR><TD CLASS="quote">hmmm,
Chris</TD></TR></TABLE>
that is correct. the s02's used on our cars is different from the current pole positions. this only holds true for the rear. honda had bridgestone specifically design these for our car. at the time s02's were available, there were 3 versions of the 225/50/16. One was the standard size, one was for a porsche, and one for our car. If you sat all 3 side by side, you see the width and tread patterns were all different. why honda did this? no idea, just made it a pain when changing to another tire.
reasoning is here, go down 3-4 posts
http://www.s2ki.com/forums/ind...48572
I thought I would add that the Toyo Ra-1s measured tread width is 8.65 and the measured tread width on my old S-02's is almost identical in the 225 sizing. The Porsche size of S-02 is .4" smaller.
-Chris
-Chris
I haven't ever spun out and I have pushed the car quite hard. </TD></TR></TABLE>
I've spun mine out twice, both times on stock tires, but it was from coming into the corner too hot, not oversteer. It shouldn't be as big of problem now with my Advan Neovas. MMMM, Advans....(Homer Simpson voice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAallTheWAY »</TD></TR><TR><TD CLASS="quote">
i never spun out on the s02's but the rear has come loose on me a couple times on the track. now on ra1's, i have spun twice now. once from overheating the tires and the second from driving on some mud that was on the track
</TD></TR></TABLE>i never spun out on the s02's but the rear has come loose on me a couple times on the track. now on ra1's, i have spun twice now. once from overheating the tires and the second from driving on some mud that was on the track
ak-s2000
Jan 29, 2004 08:28 AM
