Kenwood head unit with no code.
Old Jul 28, 2005 | 08:50 AM
TahitianEG's Avatar
Default Kenwood head unit with no code.
I bought my honda back in April and at that time I didn't know that the Kenwood stereo had an anti-theft code that had to be entered to "unlock" it if the constant power was disconnected. I had to disconnect my battery for some work I was doing and now my head unit is asking for the code. The previous owner doesn't have any info on the stereo. I'm hoping someone here might be able to help. It's a Kenwood KDC-322 I don't have the serial number handy, but I could try and get it.
Old Jul 28, 2005 | 09:02 AM
CooBlueDAB's Avatar
Default Re: Kenwood head unit with no code. (Sponger)
it isnt necessary unless the previous owner put in the security code, which he did... hence... he should know the code he entered as the password...
Also, short of using the serial number and calling kenwood, you may need the little card that came with the new units, .... it is used in case of theft to replace the face plates, however I believe it is for the code as well.... good luck....
Old Jul 29, 2005 | 07:23 AM
TahitianEG's Avatar
Thanks, I've already tried Kenwood to see if they could help but I haven't gotten any response. I think the receiver is toast.
Old Aug 3, 2005 | 02:37 AM
khabi khabi's Avatar
there is a universal code for those,i belive it was 0000,then hold down the button with the little square marked next to it,sorry it has been a while,if not ,call kenwood customer support,you will probably have to send the unit to them.
Old Aug 3, 2005 | 12:44 PM
B--RYAN's Avatar
Default Re: Kenwood head unit with no code. (khabi khabi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khabi khabi &raquo;</TD></TR><TR><TD CLASS="quote">there is a universal code for those,i belive it was 0000,then hold down the button with the little square marked next to it,sorry it has been a while,if not ,call kenwood customer support,you will probably have to send the unit to them.</TD></TR></TABLE>
Old Aug 3, 2005 | 02:10 PM
TahitianEG's Avatar
Thanks for all the help, I'll try that in a few. Being that I'm at work and all, I'll need a few minutes to try that. Hopefully that'll work.
ukrkoz
Honda Civic (2006 - 2015)
Dec 8, 2014 06:19 PM
danteisme
Audio / Security / Video
Jul 20, 2007 10:23 AM
4rcefeddeceiver
Acura TL, RL & ZDX
Sep 29, 2005 12:50 PM
K I O K E N
Aug 2, 2004 02:00 PM
UNDER PRESSURE
Jul 1, 2003 09:17 PM
