ignition problems...
Old Jul 28, 2005 | 08:10 AM
pandacivic's Avatar
Default ignition problems...
...not sure how to explain this problem...
i started my car this morning, it was running for a good while. i noticed the a/c was left on from last night. i turned that off, the whole car just died. i tried to start it again and no worky. when i put it in the "on" position, the check engine, brake, srs lights and watever else that are supposed to turn on didnt. i also noticed that when my door is open, the beeping still beeps. what's the deal? basically my car is dead. but not really dead. what fuses do i need to check? i checked the main ones and some others, am i missing something? please help me.
Old Jul 28, 2005 | 08:39 AM
blackbmagic's Avatar
Default Re: ignition problems... (pandacivic)
umm check ur batt first it may be dead...reason its beeping is because it takes less batt power to make that beep than to turn the lights n stuff on..does the engine still turn over?
Old Jul 28, 2005 | 08:44 AM
pandacivic's Avatar
Default Re: ignition problems... (blackbmagic)
thank you. i've checked the battery. everything works fine. lights and all work. but i'll check it just to make sure. it's just when i turn the car on "on" it's supposed to kill the beep and light up. didn't do that. it was as if the keys were in the ignition and the door was open and the beep stayed. not even getting to start. so that's freaky.
spyke01
27
Apr 26, 2013 10:29 PM
99SiGuy.
Jun 20, 2012 04:23 PM
quichocho89
Mar 27, 2010 10:12 AM
[JDM]noob
Dec 7, 2009 07:20 AM
jetmex
16
Sep 7, 2009 01:30 AM
