Suspension & Brakes Theory, alignment, spring rates....
Suspension gurus,do I need a camber kit,just an alignment or both?
Old Jul 28, 2005 | 07:20 AM
$amGD3's Avatar
Swaggylicious
Default Suspension gurus,do I need a camber kit,just an alignment or both?
Just got back from Tire Kingdom and my toe/camber is fudged up.Do I need a camber kit,just an alignment or both?
Old Jul 28, 2005 | 07:33 AM
wannabe_si's Avatar
Default Re: Suspension gurus,do I need a camber kit,just an alignment or both? (sam21)
id say just get the toe set and not worry about the camber
its not all that bad
Old Jul 28, 2005 | 07:39 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Suspension gurus,do I need a camber kit,just an alignment or both? (wannabe_si)
I would say get your toe set also, and don't worry about the camber (you don't have much anyways). Their does seem to be a problem with your front caster though. You may want to get that checked out. Usually a part is bent or out of spec when your caster is off (Honda's don't have adjustable caster because it effects bump-steer).
Old Jul 28, 2005 | 09:41 AM
Tyson's Avatar
its actually a good camber spec. i like ot see it around -1.5 each side. why? i dunno, it certainly is a bit relative to the height and and particular type of drivng, but whatever, i like it!
yeah, just dial back the front toe to 1/16 TOTAL toe out, or just make it straight. then zero out the rear thrust angle. it be sweet...
Old Jul 28, 2005 | 03:32 PM
$amGD3's Avatar
Swaggylicious
how would I zero out the rear thrust angle?
and 94eg!
what's wrong with the front caster,isn't in the green thing good?
Old Jul 28, 2005 | 03:43 PM
Tyson's Avatar
Default Re: (sam21)
your caster is fine. i wouldnt touch it.
the thrust angle is set by the relative angle of the TOTAL rear toe to the chassis. its off, both whel are pointing right.
are you going to do the alignment yourself???
Old Jul 28, 2005 | 07:47 PM
$amGD3's Avatar
Swaggylicious
dear God no,gonna take it to a place
Old Jul 28, 2005 | 07:54 PM
Tyson's Avatar
Default Re: (sam21)
then dont worry about it. theyll do it.
Old Jul 28, 2005 | 08:07 PM
AutoXer's Avatar
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">your caster is fine. i wouldnt touch it.
are you going to do the alignment yourself???</TD></TR></TABLE>
Here's a good reference I always point people towards to help understand toe / thrust angle:
http://www.tirerack.com/tires/...hid=4
They should be able to get the toe and thrust angle to 0, and the rest looks pretty good.
Old Jul 28, 2005 | 09:47 PM
veggiemaster's Avatar
Default Re: (AutoXer)
Check your front LCA bushings as well. I have seen those really throw off alignment numbers.
And i would say a -1.5 is a good camber to have, i would leave that alone.
Old Jul 29, 2005 | 07:43 AM
Budget EJ's Avatar
Default Re: (veggiemaster)
Are there any other "Tire Place" chains in the midwest that can do these services as well? I hear of some places that say they can't adjust anything if you have an aftermarket suspension setup. I need to get specs on my alignment too!
Old Sep 5, 2005 | 05:16 PM
badsha's Avatar
Default Re: (Budget EJ)
Hi guys,
I see how you helped the original poster out. I was hoping you guys could help me out. My front tires were bald on the inner part of the tire. The car pulls hard to the right. Tires were balanced and had an alignment done. I have front and rear camber kits. I NEVER saw the people at Firestone adjust the camber. The car is an Accord EX dropped on TEIN SS with SPC front and rear camber kits. Do i have to adjust the camber in the front to make the car stop pulling so hard to the right and stop the tires from balding prematurely? Please guys help me out. 225/40 tires are freaking expensive. Here are the latest alignment specs.
JdmB16Eg6
Suspension & Brakes
Mar 28, 2006 10:29 AM
.water
Suspension & Brakes
11
Oct 23, 2005 08:24 AM
lilhatch
Sep 24, 2005 06:40 PM
vdub08
Suspension & Brakes
19
Sep 3, 2005 01:14 PM
TypeR II
Suspension & Brakes
Jun 3, 2005 02:21 PM
