good brand for a clutch and flywheel
Old Jul 28, 2005 | 05:13 AM
hb_rule_b18's Avatar
Default good brand for a clutch and flywheel
i am looking for a stage 3 clutch and i want to lighten my fly wheel and i was to know a good brand that won't cost me alot of money. i have a b18 engine
Old Jul 28, 2005 | 05:51 AM
machine4321's Avatar
i tihnk you really get whatyou pay for when it comes to a clutch ....ive learned the hard way .
many companies take a cheap aftermarket oem pressure plate and simply repivot it making it have a higher clamping force but the negitive effect of that is alot less pedal travle ,as well as less travle of the pressure plate ...this will lead to a draggign clutch and alot more miss shitfs/grinding gears.
my recomendation is to stick with a company known to manufactur there own PP assemblies
exedy
ACT are my top recomendations as ive used both ...the act is my favorite as it feels litk a stock clutch with a bit stiffer pedal ..its got great linear travel and has never given me any problems
ive heard good and bad about centerforce but ive never used them so i cant coment
there is alot of people making clutches out there do you research and you should make out ok
Old Jul 28, 2005 | 07:13 AM
B18CR_EJ2's Avatar
Default Re: (machine4321)
fidanza makes great flywheels and all my buddies use clutchmaster in their h22s????? its up to you man, its like he said you get what you pay for...
Old Jul 28, 2005 | 07:35 AM
phyregod's Avatar
Default Re: (B18CR_EG)
EXEDY ALL THE WAY. I wouldn't put any other clutch in my car.. Good stuff! (and they dont rape you on the prices.)
Old Jul 28, 2005 | 07:47 AM
i run fidanza flywheel ...great bang for the buck
Old Jul 29, 2005 | 02:23 PM
sir boostalot's Avatar
i got an act clutch and flywheel setup, but i wouldn't recommend getting bearings from them, I've had a problem with my clutch and disk, and especially bearings along with other people that i know. Within months I lost grabbing power, started getting squeals n ****, it is a good clutch when working (i had the HD 6puk) but make sure you get a legit install.
RobbieG35
Honda S2000
Mar 17, 2006 05:27 AM
JDMorgan
Jul 5, 2004 09:00 PM
danny98r
Jun 24, 2004 12:15 PM
-[95cxhatch]-
Mar 1, 2004 01:22 PM
EVOCELICA
Oct 13, 2001 11:36 PM
