Electric water pump on a daily driver????
Old Jul 28, 2005 | 04:17 AM
kndaqikEG's Avatar
Default Electric water pump on a daily driver????
Should this even go here? Who knows but I dont think anyone else is using electric water pumps so its ok . I am curious if anyone else is doing this or what are some opininon on the subject. I am thinking about installing a meziere electric water pump and driving daily ( every day ) for a while, then like every couple of days daily after a few months. Good idea, bad idea? What do you suggest?
Old Jul 28, 2005 | 04:22 AM
wishingiam's Avatar
Default Re: Electric water pump on a daily driver???? (kndaqikEG)
I've been running mine for awhile only drawback is the holes you drill in the thermostat makes warming up the car a chore takes about 10 minutes for mine in a hot climate (Hawaii). No problems here, but in the near future the only problem I see is that electric pumps don't last to long and replacement are'nt cheap.
Old Jul 28, 2005 | 07:43 AM
kndaqikEG's Avatar
Default Re: Electric water pump on a daily driver???? (phuckyou)
What holes in thermostat?
Old Jul 28, 2005 | 01:43 PM
wishingiam's Avatar
when you run an electric water pump they recommend you drill a small hole so it'll have a little flow while the thermostat is closed if not it'll build up to much pressure stressing the pump and your hoses.
Old Jul 29, 2005 | 07:43 AM
kndaqikEG's Avatar
Ok, that makes perfect sense. Thermostats usually already have a small hole in them for the same purpose, so I will need to add another then? Is there a specific size recommended by each manufacturer or just a general size for the majority?
Old Jul 29, 2005 | 01:22 PM
Pondus's Avatar
I'm going to do it, but will also use a Davies-Craig electronic pump speed controller to regulate the water pump. This should help get rid of the long time it takes to get the water up to operating temps as the pump will be running slow until the temp sensor starts to read higher temps.
Old Jul 29, 2005 | 03:04 PM
wishingiam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kndaqikEG &raquo;</TD></TR><TR><TD CLASS="quote">Ok, that makes perfect sense. Thermostats usually already have a small hole in them for the same purpose, so I will need to add another then? Is there a specific size recommended by each manufacturer or just a general size for the majority? </TD></TR></TABLE>
Yes just drill one extra hole I can't remember what size it was though. The instructions should say what size. As for the long warm up time I was gonna run a switch to an ignition source, so I can turn on the pump only when the ignition is on and the car is warmed up, and if I forget to turn the pump off, it'll turn off when I shut the engine off.
Sickteg24
Aug 16, 2012 08:01 AM
cadougherty_67
Mar 29, 2005 06:21 PM
tominos
Sep 10, 2004 08:38 PM
RI_TM
Jul 31, 2004 12:22 AM
b16supertuner
Jul 14, 2003 06:17 PM
