GSR ish into LS block, Questions
Old Jul 28, 2005 | 02:30 AM
steelies's Avatar
Default GSR ish into LS block, Questions
I'll be rebuilding soon, and had a few questions.
I've got an LS block. And I've got a GSR crank, eagle rods, and weisco pistons. My question is. What more will I need to swap in to make all this work? GSR crank pulley? or will the stock LS one work? What about the oil pan and windage tray and all that good stuff?
I appreciate the help.
Old Jul 28, 2005 | 04:41 AM
quickcarl's Avatar
Default Re: GSR ish into LS block, Questions (steelies)
everything else from the LS will work. The water pumps are different, but if you use LS water pump, head, timing belt, etc. it will be fine. The GSR oil pump would be a good improvement if you can get one.
Old Jul 29, 2005 | 03:24 AM
steelies's Avatar
Default Re: GSR ish into LS block, Questions (quickcarl)
I've got a line on a brand new b18c oil pump that will most defintely be going in.
The build should commince early next week, and have the car back the following week hopefully.
DC2fab
Jan 16, 2010 01:37 PM
mymeatb18"
18
May 11, 2006 06:17 PM
User 42624
Nov 1, 2005 10:35 PM
TheThiefTheKnife'NTheGun
Jan 19, 2005 10:20 AM
tnsxsear1
Feb 8, 2004 03:33 PM
