how do you adjust the clutch (dc2)
Old Jul 27, 2005 | 11:10 PM
sickofitall1113's Avatar
Default how do you adjust the clutch (dc2)
i need to know how to adjust the clutch cable. i would like it too catch closer to the floor. anyone know or have a picture or what-not
Old Jul 28, 2005 | 08:17 AM
Default Re: how do you adjust the clutch (sickofitall1113)
bump
Old Jul 28, 2005 | 08:24 AM
Preferio's Avatar
it's hydraulic... you cant(if you're talking about a DC2)... if it were a DA, then you could because it's cable... Have you switched out your hydraulic tranny for a cable tranny??!??! Are you talking about adjusting the pedal rod maybe?
Modified by 95IntegraLSR at 9:37 AM 7/28/2005
Old Jul 28, 2005 | 10:36 AM
Default Re: how do you adjust the clutch (95IntegraLSR)
mmm now that you mention it, it totally slipped my mind...no its the stock tranny so i guess it stays the way it is.
Old Jul 28, 2005 | 10:48 AM
Preferio's Avatar
yep... you can try to change out the fluid.. over time they will get moisture in the hydraulic system... best way to bleed a slave cylinder is to let it run out slowly and jsut fill it as it goes down...
Vash121991
May 22, 2012 12:47 AM
lilo_goki
13
May 9, 2007 10:34 AM
NSfit
Oct 11, 2006 04:29 PM
SnowSurfer
10
Jun 15, 2005 01:57 PM
xlusiveracer
Feb 28, 2005 02:32 AM
