Problem with d15b install
Old Jul 27, 2005 | 09:54 PM
Paperweight's Avatar
Default Problem with d15b install
I got a 91 CRX Si. The a6 didnt have enough ***** so I got a turbo. but I got a JDM d15b motor to go with it. I got the motor in, and I think I got all the wiring done. but when I turn the Key it clicks, as if there was a dead battery. however all my electronics work, now I got a dizzy from pep boys. its from a 92 civic si. I dont know what wires go to which on the engine harness... i am going insane trying to figure this out. any help would be appreciated... also what color wires go to which on the 02 sensor? i am using a boom slang harness also.
thanks
casey
Old Jul 27, 2005 | 10:26 PM
Redline130's Avatar
Default Re: Problem with d15b install (Paperweight)
What ecu are you using? Did the harness not come with instructions or a wiring chart?
Old Jul 27, 2005 | 10:35 PM
NikoZai's Avatar
Default Re: Problem with d15b install (Redline130)
Click could be that the starters frozen, get a volt meter and see if the voltage drops below 12v+ at the battery when you attempt to start. Then check all your starter connections, starter ground especially. (slip on terminal)
Beyond this starter/ignition problem, we can diagnose all your problems if you tell us your entire setup and what you re-wired.
What injectors are you using?
What ECU?
What distributor exactly?
You're still using the Si engine harness right?
And why are you talking about your distributor if the engine wont even turn over?
This is a bad sign, it could be that the owner of the vehicle is defective.
If you have a defective owner, your only option is to sell the car immediately to a new owner.
Old Jul 28, 2005 | 01:04 AM
Agent_STFU's Avatar
Banned
Default Re: Problem with d15b install (NikoZai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NikoZai &raquo;</TD></TR><TR><TD CLASS="quote">
If you have a defective owner, your only option is to sell the car immediately to a new owner.</TD></TR></TABLE>
Thats one of the more common vehicle problems.
Old Jul 28, 2005 | 01:16 AM
Magick211's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NikoZai &raquo;</TD></TR><TR><TD CLASS="quote">|
Heh
turbob18si
Audio / Security / Video
Dec 21, 2007 12:23 PM
blu eg22
Jun 15, 2007 04:22 AM
Mr_CRX
14
Dec 9, 2006 01:53 PM
Maireeka
13
Dec 6, 2006 12:32 PM
baastard
May 25, 2006 07:52 PM
