Need some help/info about pillow ball mounts
I am looking at http://www.truehonda.com/inven...d=377 for my ep. I see they come with pillow ball mounts. My understanding is pillow mounts can sometimes be used to adjust camber so you dont need a camber kit.
I am wondering if I correctly understand what pillow mounts are used for and are the ones included in that link able to used instead of a camber kit?
Thanks
Thanks
I read the description of that product and while it mentions pillowball mounts, it does not state that they can adjust your camber. Besides, if I remember correctly, the camber adjustments on your EP are at the bottom of the shock where it mounts to the knuckle.
Yes pillowball mounts on MacPherson strut suspensions (like the front of your EP) can be used to adjust camber IF they are slotted. Some OEM MacPherson struts have no camber adjustment and thus need a slotted upper pillowball mount. Yours, however already has adjustment from the factory so a slotted pillowball upper mount would be redundant (unless you wanted to adjust your shock angle but that's way beyond our scope here).
hatchb18c
Suspension & Brakes
May 26, 2009 04:07 PM
kakahoya
Apr 21, 2008 05:13 PM
LS2ner
Suspension & Brakes
Apr 30, 2006 02:15 PM
KSE
Aug 19, 2004 11:06 PM
jisu009
Apr 14, 2003 10:24 AM
