ZC SOHC?
Old Feb 19, 2002 | 09:24 AM
Slapnuttz's Avatar
Default ZC SOHC?
well i have a 91 Si hb and my motor went out on it (d16A6) and my friend went and got me a new on for my car and the block # was (ZC) thats it no other # where on the block. and its a SOHC just like the d16a6.
can any one give me some info about the new motor im going to have in by tonight?
Thanx.
Old Feb 19, 2002 | 09:36 AM
REDBARON's Avatar
Default Re: ZC SOHC? (Slapnuttz)
Do a search on here and see if someone has already talked about this engine. If not, go to hybrid.honda.org, and they have some info there.
Old Feb 19, 2002 | 09:43 AM
WuShu's Avatar
New User
Default Re: ZC SOHC? (VTECHatch)
we have talked about it already, i got this motor, its 118hp.
Old Feb 19, 2002 | 11:24 AM
RexB16's Avatar
Default Re: ZC SOHC? (HondaCRX)
ya the the sohc zc, the lesser known of the two zc motors. thats a pretty nice friend you got there.
Old Feb 19, 2002 | 01:48 PM
Slapnuttz's Avatar
Default Re: ZC SOHC? (RexB16)
well he is a good friend!
well what are the shift points and the ZC SOHC and what is the rev limit in it.dose this ZC have Vtec? is there any good sights on this motor because i would like to get specs because i would like to bild this one up.
should i use the same ECU or is there a nother one that is better.
thanx for the info guys!
[Modified by Slapnuttz, 12:49 AM 2/20/2002]
Old Feb 19, 2002 | 05:45 PM
ViperRedCRX's Avatar
no vtec, the si ecu will work fine, but try to find a zc.(86-89 teg)
Old Feb 19, 2002 | 07:36 PM
CimorelliCRX's Avatar
Default Re: ZC SOHC? (d16crxdxr)
Will any 86-89 TEG ECU work, 5 speed, with a DOHC ZC. I found a junkyard that has them for 10, but i got hte 87.. Freind told me it wont work, only 88-89..
Old Feb 19, 2002 | 09:29 PM
RexB16's Avatar
what he said
Old Feb 19, 2002 | 10:27 PM
Default Re: ZC SOHC? (CimorelliCRX)
if you can get zc ecu's for 10, them i want like 5...be sure...pm7
Old Feb 19, 2002 | 10:53 PM
JDM CRX's Avatar
heres the deal
there is a ZC SOHC motor,, thats what i have in my CRX,, mine runs a 14.47 n/a
how might you ask?> it was a carbed engine, i pulled that **** off and put on Fuel injection, becuase the stock ZC SOHC carb engines cam is more agressive and therefor with the fuel injection on it, overall it has more power, anyhow, i got DC 421 headers, 1.8 integra ECU with 1.8 injectors, greddy exhuast, tailor wires. this engine smokes the ZC DOHC engines, so dont fret, it is a good engine that winds up quicker than its big brother the DOHC ZC,, stock HP on the fuel injected models is 129 on the SOHC and 135 on the DOHC---both JDM specs
i hope some of my top secret CRX info helped out. later
PS i have the SI model,,,, which has the nice inhector resistor box!!
Old Feb 20, 2002 | 05:41 AM
WuShu's Avatar
New User
Default Re: ZC SOHC? (JDM CRX)
hey whered you get all this info from? this is interesting cuz i got a spare si motor and a couple extras.
Old Feb 20, 2002 | 07:17 AM
I was talking about the teg ECU for 10, not ZC for 10. I was wondering if the 86-89 Teg ECUs work, I thought only the 88-89 worked.
Old Feb 20, 2002 | 09:36 AM
JDM CRX's Avatar
i got most of this info from the guy i buy my engines from (soko america) and ive done this to 4 engines so far and it puts out greater torque with this setup.its really is noticeable, ive smoked and surprised many people with my little d16,, you can make that enigne putout around 220 Hp n/a... how? heh heh heh
port and polish the intake/head,bore over the throttle body(optional), get a dope cam, higher compression pistons-13-1's
get a retuned ECU or AFC, get a adjustable cam gear and let me tell you, that little bitch for a d16 will scream like a freshman on prom night, best of all its inexpensive for all those parts. hope this tech helps you out!
Old Feb 20, 2002 | 09:37 AM
i think all those years work...the ecu's are what i'm talkin about...can u really get them for 10?
Old Feb 20, 2002 | 09:38 AM
JDM CRX's Avatar
BTW the 86-88 integra ECU works ONLY THE 5-speed ECU!!!!!
the automatic one wont!!!
and of course the 89-up one works as well
manual only!!!
my freind learned the hard way by buying a ECU from a automatic integra,,,,
**** didnt work, and he was out 30$
--------peace out
Old Feb 20, 2002 | 10:00 AM
therealciviczc's Avatar
Forgive me if I'm wrong, but I'm fairly sure that the 86-87 teg ECU won't work. Isn't that motor carbed (or dual point)?
Old Feb 20, 2002 | 10:09 AM
JDM CRX's Avatar
Default Re: ZC SOHC? (therealciviczc)
im sure the carb integra wont work,, but the integra my freind got his off of was a 87, it was fuel injected and his car is running proof that it works.
Old Feb 20, 2002 | 07:02 PM
ACtually, I found the 89 today at the junkyard and stole it,
No, the 86*87 have 12 valves, so I dont think they will work.
Old Feb 21, 2002 | 09:47 PM
Slapnuttz's Avatar
well thanx for all the info guys its been real help full
Old Feb 22, 2002 | 02:02 AM
91ED7Si's Avatar
the 86-87 integras have vacuum advance bullshit so no they dont work.
Old Feb 22, 2002 | 09:28 AM
JDM CRX's Avatar
Default Re: ZC SOHC? (91ED7Si)
look, ive heard like 5 different things from 5 different people as to why that ECU wont werk,, (86-87) i know for a FACT that my freinds ECU is out of a 87, yes a 87 integra, ill go and steal the friggin plate off the chassis that says the year, scan and show you all, anyhow, that one works, i dont care what others say, the engine in that car was fuel injected no vacuum advance, not TBI, i dont know which model the car was, but it works, enough said
----peace
patrickstar
30
Dec 27, 2008 07:02 PM
itsJDMyo
Dec 13, 2003 10:57 AM
CRneXt
39
Oct 7, 2003 02:13 PM
Ef Whore
Jan 2, 2003 05:36 PM
