NO dashlights, got new battery. HELP!
recently i blew a fuse to my interior lights. i replaced it, and now it drained my battery so i couldn't start my car. I did it everytime, so i went to get a new battery.
but i don't want the new battery to drain like the old one. I have no dash lights, my speedo is off, and the clock doesn't show unless i press the cover. i get a big shock when i step out now too. i've only checked that valve cover ground and thats cool.
any advice?
[Modified by BoM, 1:25 PM 2/19/2002]
any advice?
Check your underhood fuses also to make sure nothing else is blown....also make sure new fuse didnt blow right away or melt....electrical probs are the worse.....did you add anything electronic to car recently....radio? lights? etc.?
Sounds like you have a short in your wiring somewhere.... What were you doing to the car before the fuse first blew? I'd guess a hot wire is loose somewhere and slowly draining your battery. Fuses won't help - you need to do some continuity testing.
only electrical things i have done to the car: is a tach, and s2k antenna.
for the tach i've uninstalled.
and the s2k antenna its fine no problem cause i had that first.
as of now, i've replaced some fuses, but now i have no turn signal lights or rear lights.
i've taken the whole tach out.
dings35
Honda CR-V & Element
May 27, 2013 06:23 PM
EusebioSam19
Aug 12, 2012 01:29 PM
R-81DC2
Jun 5, 2007 09:21 AM
trade it in and get a itr ...
