del sol?
Old Jul 27, 2005 | 06:57 PM
ej1_jdm's Avatar
Default del sol?
i tried searching for this topic and didnt have the out come that i wanted. im wondering if the del sol rear disk will swap to replace my drums i have so i can have rear disks all the way around. and if they will swap is $100.00 sound legit for the brakes?
thanks in advance
-Mark
Old Jul 27, 2005 | 07:09 PM
dr_latino999's Avatar
Default Re: del sol? (ej1_jdm)
Yes, the trailing arms are the same (I believe, don't quote me on that or I will find you and smite you).
Old Jul 27, 2005 | 07:11 PM
ej1_jdm's Avatar
Default Re: del sol? (dr_latino999)
i dont know much about brakes.. but i know what trailing arms are... so if they do fit that swap is ok?
Old Jul 27, 2005 | 07:21 PM
Yes, just use your stock suspension components, I.E. everything attached to the trailing arm by bolts and you should be fine. Also if you have a hatch or sedan you have to use Integra E-Brake cables and if you have a CRX you must procure 90-91 CRX Si E-Brake cables.
Old Jul 27, 2005 | 07:23 PM
Crx Jimmy's Avatar
yes get the whole trailing arm assembly w/ebrake cables, dont worry about the cables they WILL fit they are just a little longer
Old Jul 27, 2005 | 07:33 PM
ej1_jdm's Avatar
dr latino: i own a coupe
crx jimmy: so if they are longer does that mean when i pull up the ebrake the lever is juss going to sit higher?
jmpassey
Sep 4, 2017 08:45 PM
raymas8
Oct 22, 2005 05:44 PM
cpizzy
Dec 20, 2003 08:02 PM
CrxSi707
Apr 8, 2003 01:51 PM
I_love_my_Crx
Mar 10, 2003 01:21 PM
