Help me spot '99/'00 EX/DX at the junkyard
Hi all,
I need to pick up an ECU connector from a 99/00 Civic DX or EX at a junkyard
1) How can I tell the 99/00 apart from the 96-98?
2) Where is the ECU mounted?
TIA
TIA
The ECU will be located underneath the passengers side kick panel on the interior of the car. Honestly i believe the plugs are the same, they may be different, but both are obdII so there shouldnt be a difference. Here's a helpful link.
http://www.hondata.com/techecuid.html
For what I've seen the plugs and even the ecu look the same, but there should be because there's a sensor in the gas tank on 99/00 that the 96-98 doesn't have and is going to give you a check engine light. I have the 96-98 ecu and 99-00 in my house, and I didn't pass inspection because of the 99-00 ecu check engine light.
i got some plugs for sale but dont know if theyre obd2b.
https://honda-tech.com/zerothread?id=1281583
You can see the 99-00 plugs are long and doesnt use the really short one at the end. The 96-98 plugs has that shorter one. So 3 long plugs about the same size = 99-00. 2 long ones about the same size and a short one about half the size compared to the longest plug = 96-98.
99-00 = first top one
96-98 = second from top
So you need the same for Integra, and for Accord? I noticed you post the exact same thing almost in two other forums.
You should try local yards, first.
It's because I just need the connector, and thanks to Quickk 99's link I can see that there are more cars than I thought that have the OB2b connectors.
I need the connector because I'm adapting an OBD2b AEM ECU to a non supported car, so I need the connector to connect it to my car.
Anrdres, can you tell by the picture wadup linked if you have the correct connector?
Thanks all.
Thanks all.
Nameless RB26
Sep 16, 2003 01:32 PM
