which spark plugs to use w/ JRSC??
Old Jul 27, 2005 | 03:25 PM
vgsr's Avatar
Default which spark plugs to use w/ JRSC??
I just wanted to know the part number for the plugs I should be running for a JRSC on 6psi on my GSR. Can somebody please post up the part number for one step colder plugs, both platinum and iridium NGK plugs? I need to order these soon, thanks.
Modified by vgsr at 4:39 PM 7/27/2005
Old Jul 27, 2005 | 04:30 PM
jBj's Avatar
jBj
Default Re: which spark plugs to use w/ JRSC?? (vgsr)
NGK bkr7e
part # 6097 or 1283
I use them in my turbo gsr, gapped to .030
Old Jul 27, 2005 | 06:15 PM
vgsr's Avatar
Default Re: which spark plugs to use w/ JRSC?? (jBj)
oh, ok, cool....are those part numbers for both the platinums and the iridiums? which part number is for which? thanks
Old Jul 27, 2005 | 06:24 PM
Ultra Jurassic's Avatar
bkr7e-11. gapped varies from 0.28 - 0.30 . . and you should be fine
Old Jul 27, 2005 | 06:49 PM
elpiar's Avatar
Default Re: (Ultra Jurassic)
I did this for my turbo teg also. Just wondering, why the small gap compared to standard gap? any explanation?
Old Jul 27, 2005 | 09:04 PM
jBj's Avatar
jBj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vgsr &raquo;</TD></TR><TR><TD CLASS="quote">oh, ok, cool....are those part numbers for both the platinums and the iridiums? which part number is for which? thanks</TD></TR></TABLE>
Those part #'s are for the same plug, on is bkr7e one is bkr7e-11. only diff is one is pre-gapped but you will want to change that anyways.
Hit up ngk.com to search more plugs
http://www.ngk.com/default.asp
Old Jul 28, 2005 | 09:31 AM
vgsr's Avatar
cool, thanks
Old Jul 28, 2005 | 03:22 PM
vgsr's Avatar
i found some NGK BKR7EIX-11 Iridium spark plugs at a local Napa auto parts store for $9.12 each, and they can be there in one day, is that a good price? The price comes to $39.49 including tax.
Old Jul 28, 2005 | 04:34 PM
jBj's Avatar
jBj
Just get the bkr7e, get them to order you those.. dont bother with iridium. i got mine for about 2-3 bucks each as far as i remember..
Old Jul 28, 2005 | 08:53 PM
vgsr's Avatar
shouldnt i be using at least platinum tipped plugs?...rite now i have platinum plugs for a stock setup from honda. i figure if im gonna get them, i might as well do it w/ real good plugs
does it even really make a difference between regular plugs and platinum/iridium plugs when thinking about what is better to use for the car?
and also, is it true platinum and iridium plugs are known to detonate on forced induction cars? if so, which type of plug is the best to use on my JRSC GSR setup, regular copper, platinum or iridium? thanks
Modified by vgsr at 11:22 AM 7/29/2005
Old Jul 29, 2005 | 10:23 AM
vgsr's Avatar
bump
Old Jul 30, 2005 | 08:29 PM
vgsr's Avatar
bump
Old Jul 31, 2005 | 08:12 AM
DC2Slow's Avatar
just stick with bkr7e-11 you will be fine.
Old Aug 1, 2005 | 10:25 AM
vgsr's Avatar
Default Re: which spark plugs to use w/ JRSC?? (DC2Slow)
Would it be safe to run iridium or platinum plugs w/ the JRSC setup? I'll go with the regular BKR7E-11, but i just want to kno if it is safe to run platinum or iridium on forced induction. I heard that platinum and iridium plugs tend to detonate, is that true? thanks for the help
Old Aug 1, 2005 | 05:53 PM
vgsr's Avatar
bump
Old Aug 1, 2005 | 05:59 PM
DC2Slow's Avatar
i dunno know if they detonate but IMO they are a waste of money.
Old Aug 1, 2005 | 07:03 PM
HYREV2NR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vgsr &raquo;</TD></TR><TR><TD CLASS="quote">Would it be safe to run iridium or platinum plugs w/ the JRSC setup? I'll go with the regular BKR7E-11, but i just want to kno if it is safe to run platinum or iridium on forced induction. I heard that platinum and iridium plugs tend to detonate, is that true? thanks for the help</TD></TR></TABLE>Just run the standard core NGK's! They won't last as long but they work better for performance. Too much sales hype on plats or iridiums!
Old Aug 3, 2005 | 10:28 AM
vgsr's Avatar
Default Re: which spark plugs to use w/ JRSC?? (HYREV2NR)
cool, i just went to Napa and got NGK BKR7E stock no. 6097. For some reason, he wouldnt let me buy only four, so i had to buy the box of 10 bc he doesnt stock them. Oh well, at least i wont have to go back for plugs next time...
Old Aug 8, 2005 | 07:35 PM
HYREV2NR's Avatar
That sounds like a scam to me just to make U spend more $$! I'd ask to speak to the Manager. Next time just go to Advance. They'll be a little cheaper there.
Old Aug 11, 2005 | 11:34 AM
vgsr's Avatar
Default Re: (HYREV2NR)
ya, oh well now...i cant return them bc they wont accept them back...either way, if u break it down into unit price, it cost 22 bux for the 10 plugs, so its about 2.20 for each plug...seems about right i guess
ill never give that ******* business again tho
Old Aug 22, 2005 | 12:25 PM
PaImportTuner's Avatar
Default Re: (skylinedo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skylinedo &raquo;</TD></TR><TR><TD CLASS="quote">did you know that if you throw a sparkplug against a window really hard it cracks the whole window but doesn't shatter it? </TD></TR></TABLE>
yeh because of (sp?)porcelin. it can silent shatter/web windows, some windows will break like fine glass. and you dont really have to throw the hard, i can just flick em.
Old Aug 22, 2005 | 04:25 PM
gsrious's Avatar
the reason why it can shatter windows like that is because it is much, much denser than window glass.
jdmstreethatch
Oct 7, 2006 06:41 PM
vietxdragon
Aug 13, 2006 07:57 AM
DeDonDeRosa
Dec 2, 2002 10:39 AM
morepoop4u
May 21, 2002 04:20 PM
dariusz
Mar 19, 2002 01:28 PM
