Venting the valve cover
Well, I was getting a good amount of oil in my motor from the valve cover hose that goes to the intake. So, I pulled it off of the intake and pointed the valve cover hose to the ground.
I didn't want to use a breather because from what I've heard bad things happen when the breathers clog.
Is what I'm doing, okay?
I'm unsure as to why I'm getting excessive blowby.. compression is 270 even across the board. Oh well.
I wouldn't run an open system
There is some debate as to if the intake runs air into the valve cover, or pulls vapors out. Either way, you are reducing the PCV system's effectiveness by letting it run open. Now the only thing releasing crankcrase pressure is the pressure itself (ie: it is unaided by fresh air displacement, or vacuum).
Weld a slashcut tube into your exhaust at a 45 degree angle and run a hose to the valve cover breather. It will pick up some HP and prevent oil from getting into your system.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic »</TD></TR><TR><TD CLASS="quote">
I found this on summit for $30.. I'll go ahead and give it a shot. Obviously I can't use the breather, but I'll just connect the hose up to the valve cover.
Sweet, I've been having the same issues myself.
</TD></TR></TABLE>Sweet, I've been having the same issues myself.
ill let you in on a little secret, heard it works havent tired it...if some how you can tie the crank case pressure into your exhaust. still pulls out the air in the crank case. but you dont inhale the oil...get it if not i can explain more.
You don't have to order the whole kit--I just ordered the part that you weld into your header collector and the check valve--it was only like $20 from summit--why spend more when you aren't going to use all the pieces?
</TD></TR></TABLE>You don't have to order the whole kit--I just ordered the part that you weld into your header collector and the check valve--it was only like $20 from summit--why spend more when you aren't going to use all the pieces?
Lordofdark176
19
Sep 5, 2007 07:55 PM
