my new set-up
as of tonight the suspension set-up will be this..... looking for a little feedback/advice whether i have a good thing here
93 civic Si hb - b16 up front , full interior , no ac/ps/cruise along with teg rad
cx manual rack swap
gs-r 10.3 rotor/caliper upgrade w/factory rear disc
now for the goods...... kyb agx's with ground control sleeves
spring rate 200 front - 350 rear
poly bushings in gs-r rear lower control arms
ITR 22mm rear sway with skunk 2 upper tie bar and generic rear lower tie bar
no front bars for now except the factory teg subframe brace
i think thats it i'm just open to feedback on how any other tips/tricks to better my car - thanks
oh yeah corner weight gets done on wed. night at schaeffers along with an alignment, that should be everything now
[Modified by Doctor CorteZ, 5:11 PM 2/19/2002]
cx manual rack swap
Those are pretty low spring rates, especially on the front.
I'd guess most Civics here have at least ~350 up front and higher rates in the rear.
Will you be doing autocross or track racing?
Jamie! Didn't we talk about this? *Shakes head* I am gonna have to talk to you more. As Dave said you will need more spring than that.
Dave - remember - coilover rates are higher than standard so those rates, although a little soft, are not hateful for a dual-purpose car. I think it is safe to say that he IS NOT set up for drag racing.
Cobra - Who is finally ditching the pimpy cut stock spring slushbox suspension this week for some 500/600lb springs.
ok yack since you roll foo's what spring rates are you running?
drew - i think we talked about it but i just did the rear now and the springs that come with the g/c kit are 2f/180r so i need a stiffer spring up fron but i need a good rate to rock street and lite track duty - any insight
is 350 too soft in the rear should i go higher?
thanks again - Jamie
What length are those springs? If they are standard length (can't rembmer what GC default is) then you will need more rate in front for sure.
I've driven cars with anywhere from 350F/400R to 600F/900R. The first numbers are good for street use. Anything more requires better shocks and strong kidneys. 600/900 is unstreetable, but hella fun on the track.
Mike Poole - what are you running again? I like your setup.
They are those Ground Control specific "380#" springs (which are not completely linear in the front, 8" length, and 450# 7" length in the rear with the Comptech 22mm rear bar. Car is basically as high as I can get it to preserve some of the shock travel that the AGXs seem to lack. These rates are really probably just past the edge of what these shocks can handle, but they've been working well for me. If I were to do it over again, I'd either get 350/400 springs to use with these shocks, or use these springs with some Koni/Bilstein shocks. It's good for a street/track/autox all-in-one kinda car.
almost identical setup to mine.
92 si no AC/PS/cruis.. manual rack swap.. 10.3" up front
cept i run GAB revo coilovers with pillowballs.. and eibach 550F 450R
and a ITR front sway with GC race adjustable rear sway
your springs are gonna be too soft and it could be detrimental to your rear swaybar comming out of the subframe
OK, now i'm a little scared to put the itr rear bar on , now i have the 14mm gs-r one should i hold off for stiffer springs in the rear ?
maybe 400f/500r?
will i be ok with the 350 rear and maybe 300 front and the ITR bar or not?
what is the limit to run on the agx's?
[Modified by Doctor CorteZ, 8:37 PM 2/19/2002]
maybe 400f/500r?
maybe 400f/500r?
maybe 400f/500r?
I'm just saying that on my car (which is most definitely heavier than yours), that I feel like I'm pushing on the limit of the shocks with the springs I have. (what I mean to say is that I'm just over it.) I can't really give you a defined number on the max spring rate you can use on them.
If I were you, I'd maybe hold off on using the ITR bar, considering you don't have a front one. If you are concerned about the subframe tearout problem, I can say that stiffer rear springs will certainly help prevent that if you do decide to use the ITR rear bar. This tearout problem is the reason I purchased the one from Comptech.
I stole Mike P's rates and put those same springs and shocks on my 94 Si. IMHO, I could have gone a tad softer on the springs. 450x9F/380x8R.
I think the weight of the car gave it a bit of a stiffer feel, but maybe a bit too stiff for daily driving (unless you have something against your kidneys
). Flip side was that it wasn't unbearable (on DC streets) and it handled like a go cart without all the headroom. W/o a rear bar, it rotated nicely and I never experienced bumpstop washout in heavy braking or cornering.
B18C5-EH2
Suspension & Brakes
Feb 5, 2018 01:38 PM
jdmspoonitr
25
Jul 5, 2012 09:01 AM
litterbox
May 2, 2004 08:27 PM
