ECU Issues?
Here's the prob I am running my stock P28 in my EG coupe with B series motor (B16) i can only go to 7400, 7500 Rpms before fuel cut out! So basically im wondering if anyone knows where i can get a chipped P28 or if anyone is willing to trade Ecu's or where i can go get mine chipped around the chicago area? Thanks for any Help
you really really should not run your car on the wrong ecu. on top of that, revving to fuel cut is asking for major problems. Try pgmfi.org for someone who can chip ecu's, and if I were you, I wouldn't drive the car until you have it chipped.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote">short-term you will more than likely be ok (keep revs low), but you'll find the car will drive better (and faster) with the right ignition maps.</TD></TR></TABLE>
This happened with my buddy in his DA9, he was first using a P28 and it was running okay, he then got his hands on a P30 and the car ran SOO much better. Bottom line, run the correct ECU with your motor.
Sorry man I'm a trial user so i only get 5 posts per 24 hours man thats bogas, anyways im moving to dayton Ohio in two weeks to go to Sinclair for the PACT program. Is it a p30 or p28 either way I will give you a 100 unless you want a B-series Spoon ECU I have it at my house in st.louis but I can get it for you, it's worth alot more than a hundred but its OBD0 PW0 man this trial **** has to go!
