missing at idle!?!?!?
Old Jul 27, 2005 | 06:57 AM
blowme's Avatar
Default missing at idle!?!?!?
basically i have searched and came up with the usual(replace cap plugs rotor etc...)
But what i did come accross is that someone had mentioned that cams with agressive lobes sometimes do not hold a "perfect" idle which sometimes throws obd2 ecus off and triggers a misfire code. Has anyone heard of this or should i continue looking. Some people say convert to obd 1 everything will go away?!?!?
basically my problem is misfire on 12&3 that came out of no where.
compression test came back good across the board.
b16 head with rev valvetrain
s2s2 cams with gears
b18c1 block
jobforme
Engine Management and Tuning
May 31, 2008 01:48 PM
escourt23
11
Dec 2, 2005 08:14 AM
bboy21385
18
Dec 4, 2004 05:39 AM
DocV
Dec 3, 2003 12:51 PM
