Experienced opinions on a brake upgrade?
Old Jul 27, 2005 | 06:52 AM
exbrick's Avatar
Default Experienced opinions on a brake upgrade?
I had a pretty close call last night that got me thinking about brakes. (Long story short, a cop was responding to a call and blew the red light at high speed. I heard the siren just in time and scrubbed to a halt, but only with a two or three feet so spare. No harm done, but scary.)
I have the EX with 4-wheel discs/ABS and I'm wondering if they can be significantly improved upon. It saved my rear but I feel like my stopping distances could be a lot shorter. My last car (Volvo S70) was heavier but seemed to have a whole lot more stopping power. I'm pretty sure these pads are stock.
Are there any worthwhile street-worthy upgrades that I can make? How do you guys feel about the stock brake system?
Old Jul 27, 2005 | 03:30 PM
NAiL05's Avatar
Default Re: Experienced opinions on a brake upgrade? (exbrick)
You could always get some better pads that will kinda help you out. Im still runnin my stock system on my 92 and its decent.
Old Jul 27, 2005 | 11:54 PM
goowakjai
Guest
Posts: n/a
pads will give u the most noticeable diference...if u wunna go all out on a mild set up i wud say pads, rotors, stainless steel braided lines, and high quality DOT 4 fluid...and if u got the cash sum new calipers, sliding calipers arent that great.......but if u wunna be a big balla then go for a big break kit
edit: SHAMELESS PLUG speaking of pads i have a set of axxis ceramics for sale that fits 90-97 EXs if ur interested
Old Jul 28, 2005 | 03:32 AM
exbrick's Avatar
Default Re: Experienced opinions on a brake upgrade? (goowakjai)
Well, I have an '02 so unfortunately I'll have to pass on the pads. Thanks, though . Are the AXXIS ceramics better than stock? The best?
The SS brake lines sound like a good idea. It won't change how much force is applied to the rotor but will build fluid pressure at the pistons faster, right?
Old Jul 28, 2005 | 09:31 AM
jweller's Avatar
if you can lock the wheels up, or get ABS to pulse, then the biggest upgrade you can make is better tires. then pads. the axxis pads are good, but i like the Hawk HPS better than the axxis pads i had before.
Old Jul 28, 2005 | 11:18 AM
AccordTunr's Avatar
Default Re: Experienced opinions on a brake upgrade? (jweller)
EBC Green Stuff pads, stainless steel brake lines, should be very good improvment. Make sure you drain thoughouhly, put in the best brake fluide you can find, and you should be good to go.
This is the potion I will take myself when I upgrade.
Hope it helps...
Old Jul 28, 2005 | 01:05 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: Experienced opinions on a brake upgrade? (AccordTunr)
Better pads and stainless braided brake lines
rjmq06
20
Oct 22, 2009 11:58 AM
iiPancho
Dec 3, 2008 10:59 AM
iNERtIA
14
May 1, 2007 10:25 AM
blulude92
May 22, 2006 08:07 AM
ghettoracer
30
Jul 19, 2003 01:15 PM
