Replacement Throttle Body for 4th Gen
Old Jul 26, 2005 | 10:03 PM
zumiez007's Avatar
Default Replacement Throttle Body for 4th Gen
I have a 92 ex accord (f22a6) and am thinking of boring out the throttle and eventually the ITM to match. But I have also been considering just swaping it with another larger throttle body. Somone said use a H22 TB, someone else said use the S2000 TB. Which throttle bodies would bolt straight up and would provide the best gains? Thanks.
Old Jul 27, 2005 | 06:52 AM
Desslok's Avatar
Default Re: Replacement Throttle Body for 4th Gen (zumiez007)
I bought an H22 TB for mine on Ebay. It works good. I can't remember exactly what I had to do, since it's been a couple years. I think I had to make a new gasket and possibly do some grinding. But yes, an H22 will work, haven't tried an S2000.
Old Jul 28, 2005 | 09:51 PM
zumiez007's Avatar
Default Re: Replacement Throttle Body for 4th Gen (Desslok)
Any other opinions?
Old Jul 29, 2005 | 06:11 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Both the F22 and H22 USDM Tbs are 60mm stock.
I can bore either to 64mm and port match the manifold.
The JDM H22 type S is 62mm stock but that TB is rare and expensive.
the S2000 TB will fit as well as the ITR but both are only 62mm and expensive
Clock on the link in my signature for more info
twiztid00002
Jan 5, 2008 06:09 PM
hamadiscool
Jan 15, 2007 08:37 AM
LUDEacris
20
Nov 1, 2006 10:49 AM
Trbospnkr
Mar 3, 2004 01:47 AM
Jdmbsixteen
Oct 16, 2003 11:05 AM
