alignment question
Old Feb 19, 2002 | 06:12 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default alignment question
When you install new suspension on a Honda, an alignment is required because of toe-in and camber changes, correct? So I'm wondering, if I got my car all aligned, then later on decided to swap my upper shock mount bushings to polyurethane, or just removing the shock assembly for whatever reason, then putting it back the same as it was, I should not need an alignment after that, as long as it's still at the same ride height, correct?
Old Feb 19, 2002 | 07:50 AM
Crazydave's Avatar
Default Re: alignment question (PatrickGSR94)
yeah you should check the alignment anytime you mess with suspension
Old Feb 19, 2002 | 10:10 AM
EL Vap133's Avatar
Just get an alignmnet from a place that offers "Lifetime alignment".
Old Feb 19, 2002 | 10:33 AM
houston's Avatar
Default Re: alignment question (Vap133)
removing a shock shouldnt change alignment. i wouldnt worry about it..
Old Feb 19, 2002 | 11:06 AM
ebelp's Avatar
Default Re: alignment question (houston)
I'd check the alignment again just to be safe...
Old Feb 19, 2002 | 11:15 AM
bullz's Avatar
Default Re: alignment question (ebelp)
Check alignment
joelmatt89
Honda Civic (2006 - 2015)
Dec 14, 2017 06:03 PM
pumafeet10
Jun 11, 2010 08:29 PM
CreaseKeeper28
Suspension & Brakes
12
Jul 20, 2009 12:00 PM
Siegfried
Jun 1, 2007 06:42 AM
