does 99-00 civic si have the same aluminum motor mount as 94-01 integra?
Old Jul 26, 2005 | 09:28 PM
bootlegtrader's Avatar
Default does 99-00 civic si have the same aluminum motor mount as 94-01 integra?
Is the dirver side motor mount on the 99-00 civic si the aluminum mount with two bolts up and one down, like the integra? Or is it the same as the older civics, steel with two bolts?
I need to know because I need the nuts for the two top bolts (integra mount), and acura is way further than honda from me. (checked the hardware stores, no luck)Thanks
Old Jul 26, 2005 | 10:03 PM
rmcdaniels's Avatar
steel, two bolts, not like the Integra mount, sorry
Old Jul 26, 2005 | 10:15 PM
Default Re: (rmcdaniels)
thanks for the reply.
Old Jul 26, 2005 | 10:39 PM
duggy's Avatar
Default Re: (bootlegtrader)
you can always get the bracket on the block and use the alum one.
adamrich33
Nov 23, 2007 08:41 PM
lscoupe
Apr 24, 2005 11:15 PM
80884
Aug 24, 2003 10:12 AM
MeanGreenEG9
Mar 21, 2003 06:10 PM
