idle issue
Old Jul 26, 2005 | 08:24 PM
gnar kill's Avatar
Default idle issue
recently my crx has started jumping around a little bit at idle......it slows goes from 1000 to 1250 exactly about 5-10 times before going down to 500 rpms.......I don't think it is a vacuum leak.....my setup is an a6/z6 mini me converted to obd1 that throws a code 9 for no reason whatsoever.....but yeah any help would be great guys thanx
Casey
Old Jul 26, 2005 | 11:59 PM
Magick211's Avatar
Default Re: idle issue (gnar kill)
Does it only do this while the motor is still cold?
Could be a bad iacv, might want to check into that
Old Jul 27, 2005 | 12:42 AM
RexQ's Avatar
Default Re: idle issue (Magick211)
mine does the same thing except i have no codes with my ls swap. help would be nice
Old Jul 27, 2005 | 12:44 AM
FlatlineEF9's Avatar
Default Re: idle issue (RexQ)
Do a search for FITV and IACV. That should work. I had the problem before and it was the FITV.
Old Jul 27, 2005 | 06:54 AM
CaliforniaHighwayPatrol's Avatar
I put this on my car and I love it, It is a voltage stabilizer, it helps a lot.
http://cgi.ebay.com/ebaymotors...95944
Look at my Battery
Old Jul 27, 2005 | 09:09 PM
gnar kill's Avatar
Default Re: (4Banger69)
it mainly does it when it is warmed up and especially at night.......do those voltage things really work?
rx_86
20
Jan 10, 2009 10:27 AM
revhardEK
May 30, 2008 02:34 PM
racingcrx
Oct 16, 2006 03:26 PM
project_one42
Feb 2, 2005 06:30 PM
dogfood
16
Jun 23, 2004 08:45 PM
