6 or 9 pressure plate bolts on aftermarket clutch and flywheel
Old Jul 26, 2005 | 08:10 PM
DEMNTD1's Avatar
Default 6 or 9 pressure plate bolts on aftermarket clutch and flywheel
Ok got a aftermarket clutch and flywheel (Toda kit), when I mount the pressure plate on the FW, all 9 holes line up. Factory only uses 6, but should I use all 9. Is there a reason for 9 holes on aftermarket FW and only 6 on factory FW. I would assume there is a purpose or it wouldn't be there, street use vs. race use....maybe.
Searched the threads, but no answer regarding it.
I'm about to assemble it and would like your opinions, I have all 9 bolts ready....
Old Jul 27, 2005 | 02:33 AM
snowseeker's Avatar
Default Re: 6 or 9 pressure plate bolts on aftermarket clutch and flywheel (DEMNTD1)
Did you put the aliment pins in?
Old Jul 27, 2005 | 06:18 AM
TodaCivic's Avatar
Yes use all 9 that the flywheel came with.
My b16 only had 6 stock... but i used all 9 that came with it... i doubt they'd include 3 extra if they didnt think you should use em.
Did yours come with a clutch tool .. mine didnt .. but it did include a new pilot bearing.
Old Jul 27, 2005 | 03:25 PM
DEMNTD1's Avatar
Default Re: 6 or 9 pressure plate bolts on aftermarket clutch and flywheel (TodaCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker &raquo;</TD></TR><TR><TD CLASS="quote">Did you put the aliment pins in?</TD></TR></TABLE>
Alignment pins already come with the Toda FW.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TodaCivic &raquo;</TD></TR><TR><TD CLASS="quote">Yes use all 9 that the flywheel came with.
Did yours come with a clutch tool .. mine didnt .. but it did include a new pilot bearing.</TD></TR></TABLE>
Me too, no clutch tool either, but I have a universal one and friends have the one from ACT.
I was planning on using all 9 just to make sure. Thanks.
IntegraJdmb18c1
Jan 12, 2006 08:25 PM
flip1199
Nov 7, 2005 11:07 AM
JasterM5
Aug 25, 2003 11:50 AM
