Having problems with removing my steering wheel off my gs.
Old Jul 26, 2005 | 07:09 PM
Audio28's Avatar
Default Having problems with removing my steering wheel off my gs.
Hey fellas,
I'm trying to remove my steering wheel, but I'm having some problems. I removed the airbag and the 19mm bolt in the middle already.
I then tried using the oem steering wheel remover http://www.clublexus.com/forum...ber=5
But here's the problem. I screwed the two side bolts in, and started to screw the middle bolt in to pull the steerring wheel out.
After a couple of revolutions, one of the side bolts begins to get loose and seems to be stripping. I tried screwing the side bolts all the way in, but no dice, one of the side bolts seems to always get loose while the other stays tighten inside. If i keep trying to screw the middle bolt, one of the side bolts eventually will come out. I have no idea what i'm doing wrong. Please help.
Old Jul 27, 2005 | 08:30 AM
drdisco69's Avatar
Default Re: Having problems with removing my steering wheel off my gs. (Audio28)
There's a tool for that??? I just pound on the front of the wheel on either side back and forth a few times to knock it loose. Then just knock it towards you, it will pop right off. Never fails, and I've done more than my share...
foam
May 29, 2006 09:03 PM
haloseven
12
Jun 15, 2005 09:29 AM
SuicideSlide
19
Sep 30, 2004 03:50 PM
