any SKUNK2 PRO1 cam dynos?
Old Jul 26, 2005 | 06:00 PM
boosted k20's Avatar
Default any SKUNK2 PRO1 cam dynos?
im gonna get a set of SK2 Pro 1 cams for my motor and im try n to figure out what kinda HP these cams make. i did a search and found only 1 dyno which made over 190whp on a GSR motor w/ B16 pistons and SKUNK2 IM.
i hate to do one of these "How much horsepower will my car make" but i just wanna see if my guess is around the ballpark range. im Hope n to make around 200whp with my setup:
LS block with JDM P30 pistons (STD bore)
GSR head with PRO 1 cams with crower springs and retainers
(overall compression with this setup is about 11.8:1)
SKUNK2 Pro series intake manifold
cai/4-1header, 2.5" piping header back
stock injectors, FPR, 255lph walboro fuel pump
Tuning with UBERDATA done by me
Old Jul 26, 2005 | 06:11 PM
Professor15's Avatar
Get a better header and atleast a valvejob then i would say you would definatly have the potenial to pass 200whp. O and a good tuner would do wonders aswell to extract more power...
Old Jul 26, 2005 | 06:29 PM
Default Re: (drchulo)
im good with tuning. i've tuned alot of cars so i think i know what im doing.
i think i'll have to get a better header down the line. my 4-1 header is flat from bottoming out.
as for the head, i will most likely send it out to get ported.
Old Jul 28, 2005 | 10:01 AM
I:_Drive's Avatar
Default Re: any SKUNK2 PRO1 cam dynos? (boosted k20)
the ls/vtec setup that honda tuning did made 211whp without tuning. ITR Pistons .50 over, stock rods and crank. Blox spec b cams, JG header, blox intake mani, some valvetrain package with titanium retainers, and the AEM Hybrid intake. made 211whp BEFORE tuning. i think they just ran a base GSR map. they even used the stock ls tranny, oil pump, and water pump for the build. all they were trying to do was make 200+ on a single dyno run. I'm also doing an all motor ls/vtec and am using SKUNK2 Pro1s in my CRX. I went .25 over with CTR pistons, and am using ITBs I hope for 2xx whp
Old Jul 28, 2005 | 09:11 PM
vinasity's Avatar
ive got them check mysig and check boosted hybrid and tbone they had them dynod
Old Jul 28, 2005 | 09:15 PM
Default Re: (vinasity)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinasity &raquo;</TD></TR><TR><TD CLASS="quote">ive got them check mysig and check boosted hybrid and tbone they had them dynod
yup, thats the dyno i was talking about. thats the only one i seen on this forum. they have some on evans-tuning.com???
Old Jul 28, 2005 | 09:20 PM
vinasity's Avatar
search by topics created by tbone and boosted hybrid and you should find some
Old Jul 28, 2005 | 09:23 PM
vinasity's Avatar
here you go i had them saved on my computer
https://honda-tech.com/zerothread?id=1135465
https://honda-tech.com/zerothread?id=1141681
Old Jul 28, 2005 | 09:41 PM
thanks alot!
Old Jul 28, 2005 | 11:31 PM
seoul-child's Avatar
nice numbers.
Old Jul 29, 2005 | 11:00 AM
johnzm's Avatar
Default Re: (seoul-child)
https://honda-tech.com/zerothread?id=1311914
my #'s i guess more "AVG" considering stock bottom end w/low compression, and no tuning.
good luck, i really enjoy these cams
TnC
43
Sep 24, 2012 06:52 PM
Garrett
75
Jan 23, 2011 12:19 AM
Attitude1216
Feb 23, 2006 01:21 PM
boosted k20
Sep 20, 2005 08:13 PM
EK99hatch
Mar 16, 2003 07:01 AM
