Need a lil help w my 96 civic
really newb to dis and also cars jus i bought a car and i cant pass inspection coz the computer wont link to da car any1 noe anyway i can fix it myself? thanx
You REALLY need to clear up what you're trying to say.
What kind of car?
What type of computer?
Any modifications to the computer?
What year?
Blah blah blah...we need to know this.
Please, try to use proper English and punctuation. Don't need the Queens people sounding and looking illiterate.
What kind of car?
What year?
oops ok here i go then
96 civic dx not a hatchback
a b16 engine swapped (bad swap i think)
computer i think is the regular dx civic computer
but then to pass inspection the port where they plug the computer in wont link thank you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rysingsun86 »</TD></TR><TR><TD CLASS="quote">oops ok here i go then
but then to pass inspection the port where they plug the computer in wont link thank you</TD></TR></TABLE>
You need to use the correct ECU for your engine, I wannt say it's a P30 ECU.
I'd read up on your motor, car, and the wiring done with your swap. Then, ask a friend who is knowledgeable to point you out everything under your hood, etc.
Then, rephrase your question if you can't figure it out through searching. I'm having a tough time with your question.
What is your ECU code? Where did it come from? (You need to be sure about this)
Your motor is a B16a2?
Who did the swap, and why did they wire it up with the stock ECU? I am sure thats not working, unless its ghetto.
yea i just gotta find all of that out im not quite sure actually i bought the car recently like 20 days ago like it is w/ the problems so im just tryn to fix it up thats all. I have no knowledge of cars im jus good at following directions so basically im trying to fix my car w/o hurting my wallet for alot to get some "Pro" at honda charge me wayy too much to rewire things
He's talking about hooking a scanner up to teh diagnostic link. Sometimes it just flat out DOES NOT work with foreign cars depending on the scanner being used. Also if you swap the OBD setup of the car then it will not communicate.
If you have an OBD2.2 in an OBD 2.1 car it is not going to talk to the scanner unless you run an OBD2.1 computer. That will throw you codes unless you use sensor simulators. Bottom line IMHO is that you bought a car without doign yoru homework first.
Just to clarify things for those that dont know... what xEnderx said is correct. In NY they recently started being really strict will all obd2 cars. Meaning this 96+ Civic. If the car is OBD2a the ECU must be OBD2a. However, you cannot use conversion harnesses or whatever because it will not work. I dont know if maybe using a 96+ OBD2a GSR ECU will help.
ChristeanBrown
21
Oct 19, 2010 01:42 PM
