When I check for codes, my SRS flashes?
Hey guys, I've done several searches on this and I can't seem to get an answer.
When I goto check for codes on my P28 ECU (I complete the circuit by using a paper clip). When I turn my key to accessory all my car does is flashes my SRS light. I've tried 2 different P28 ECUs and the same thing happens. Am I doing something wrong?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox »</TD></TR><TR><TD CLASS="quote">WTF!?</TD></TR></TABLE>
Seriously, and I know my car is running rich too. I need to find this out guys. Please help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej1_coupe »</TD></TR><TR><TD CLASS="quote">No clue, but bump for yuou
Thanks anyways.. I always have questions for HT that no one ever knows.
</TD></TR></TABLE>Thanks anyways.. I always have questions for HT that no one ever knows.
- i think the srs might be flashing due to a wiring issue on the p28 i ran on on my b20vtec before it got stolen when i would run for codes- all my lights would flash once - as it was priming turning the key
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b204dr »</TD></TR><TR><TD CLASS="quote">- i think the srs might be flashing due to a wiring issue on the p28 i ran on on my b20vtec before it got stolen when i would run for codes- all my lights would flash once - as it was priming turning the key </TD></TR></TABLE>
See, the thing is I've tried 2 p28s. I've gotton it to work once.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b204dr »</TD></TR><TR><TD CLASS="quote">does the srs flash like the check engine light should? could be a cluster issue !</TD></TR></TABLE>
No, the SRS last flashes constantly when the key it turned to accessory.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch »</TD></TR><TR><TD CLASS="quote">My Hondata S100 P28 does the same thing when checking the codes. I thought it was normal. The check engine light still flashes when a code is present.</TD></TR></TABLE>
So does this mean that I don't have any codes? I'm going to try resetting my ECU, maybe I'll get something different.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch »</TD></TR><TR><TD CLASS="quote">I believe so. I thought the flashing srs light means you are in the diagnostics mode. If the CEL isn't flashing you don't have any codes. </TD></TR></TABLE>
Awesome, well that's really good to know then.
ive been trying to figure out why the SRS light flashes hopefully i can figure it out soon.
But if ur CEL just stays on and does not flash then you have no codes presant in the system.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">ive been trying to figure out why the SRS light flashes hopefully i can figure it out soon.
But if ur CEL just stays on and does not flash then you have no codes presant in the system.</TD></TR></TABLE>
So, when the SRS light flashes it doesn't mean that your code free? Damn, I need to figure this out.
Same thing with my '94 VX. Just different ECU. SRS flashing while CEL flashes the code.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all_conference »</TD></TR><TR><TD CLASS="quote">Same thing with my '94 VX. Just different ECU. SRS flashing while CEL flashes the code.</TD></TR></TABLE>
When I dod it, my CEL goes off like normal but the SRS continues to flash.
My car did something very similar to yours, so after me and some friends couldn't figure it out, I took it to Honda. I had an SRS issue, and not a CEL issue at all. What happen was that I took my dash out, to install white gauges and I need to reset the SRS(that I didn't do at the time). They said that they will reset the SRS, but it will cost an additional $95, and they have already charged me $74 just to tell me it wasn't a CEL issue and that it was a SRS issue. So I reset it myself, and it only took about 5 mins.
From: chillin in that city called queen creek, but homes the atl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00ekcoupe »</TD></TR><TR><TD CLASS="quote">How do you reset the SRS?</TD></TR></TABLE>
yeah
yeah
