Question About Adding a Second Resonator on a LOUD Exhaust
Old Jul 26, 2005 | 04:02 PM
litterbox's Avatar
I am a (Trial User) Army
Default Question About Adding a Second Resonator on a LOUD Exhaust
Hey,
So I know when I put my Tanabe Super Racing Medallion exhaust on it'll be way to loud. I'm going to be running a test pipe, no cat. So, before throwing out my old *** rusted *** stock EG exhaust, I cut off the resonator.
I'm thinking I could weld that resonator into the tanabe piping. Here's the thing, will adding a stock resonator to a bigger diameter piped exhaust kill power?
As most of you know, resonators widen out from the actual pipe diamter to the full diamter of the resonator. I can cut enough pipe off the resonator to make it effectively be the same diameter as the Tanabe pipe, would that help?
Any help/insight would be appreciated. I'm installing the exhaust this weekend.
Old Jul 26, 2005 | 04:06 PM
GetawayInMoscow's Avatar
Default Re: Question About Adding a Second Resonator on a LOUD Exhaust (litterbox)
With not cat and a "straight through" muffler its going to be loud regardless.
Do you know how to weld? Because I don't think an exhaust shop can do it for you.
Old Jul 26, 2005 | 04:14 PM
JDM-EJ1's Avatar
Default Re: Question About Adding a Second Resonator on a LOUD Exhaust (GetawayInMoscow)
Andrew,
To me this seems like it would kill your power, if you weld the OEM resonator into your exhaust, just think about it.. The resonator is for a stock exhaust system, obviously your exhaust is aftermarket. I think if you put the two together the out come out wouldn't be very good.
Aceboogy
May 4, 2014 08:21 AM
rotascircuit
Nov 26, 2007 08:48 PM
the.hamburglar
Feb 18, 2007 06:32 AM
kay_animation
Feb 8, 2003 04:25 PM
90DXREX
31
Apr 23, 2002 01:32 PM
