TODA?
Old Jul 26, 2005 | 03:01 PM
embidia1's Avatar
Default TODA?
i have a 99 si bought some toda cams SPEC A but im wondering if i can put them on with the stock valvetrain.
Old Jul 26, 2005 | 03:07 PM
EK k kay's Avatar
Default Re: TODA? (embidia1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by embidia1 &raquo;</TD></TR><TR><TD CLASS="quote"> i have a 99 si bought some toda cams but im wondering if i can put them on with the stock valvetrain. </TD></TR></TABLE>
So you bought new cams without knowing if they'll work with the stock valvetrain or not...
Old Jul 26, 2005 | 03:09 PM
embidia1's Avatar
Default Re: TODA? (wadup)
WELL SOME PEOPLE TELL ME YES AND SOME TELL ME NO...............
Old Jul 26, 2005 | 03:12 PM
EK k kay's Avatar
Well first thing I would've done was visit Toda's website and take a look myself..lookie what I found in a few seconds.
http://www.todaracing.com/prod....html
Old Jul 26, 2005 | 03:16 PM
embidia1's Avatar
i got the cams for 100 $ from a friend i was not going to say no..
Old Jul 26, 2005 | 03:18 PM
transpar_nt's Avatar
they technically WILL work with your stock valve-train, but its highly recommended that you upgrade. Because the lobes on your new cams are higher than the ones on your stockers, the valves essentially need to travel faster to rotate at the same speed they did before the cam swap. Your stock springs won't be able to fully keep up and will end up not closing fast enough, cause valve float. This will cause you to loose power, and eventually wreck stuff. Some people don't upgrade their valvetrain and never have problems, but that will mostly depend on the cams you bought, the quality of the oem valvetrain (ctr will obviously handle more than the CVCC), and their condition. Hope that helps...
Old Jul 26, 2005 | 03:22 PM
JDM-97CX's Avatar
Default Re: TODA? (transpar_nt)
This is easy info to find. First look up the coil bind on your stock valve springs. Then look at the lift on the cam. If it is very close, at or passed the coil bind then the cam will not work.
Old Jul 26, 2005 | 03:32 PM
Hooch'n's Avatar
Default Re: TODA? (JDM-97CX)
I would upgrade to at least ITR stuff, but you can run on your current set-up fine. Just watch the rpm's.
Old Jul 26, 2005 | 03:42 PM
embidia1's Avatar
Default Re: TODA? (Hooch'n)
took it to the dyno i lost power at 7900so i would take it to 7800 but do you think i should stay at 7800. with the todas...
Old Jul 26, 2005 | 03:58 PM
Earthworm Jim's Avatar
It will but it would work better with a complete head package.
Old Aug 4, 2005 | 02:42 PM
punx04's Avatar
what kind of #'s did u make with that? anything else to your setup or just that? was lookin to buy some of these cams
Old Aug 4, 2005 | 02:46 PM
built562's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by embidia1 &raquo;</TD></TR><TR><TD CLASS="quote">took it to the dyno i lost power at 7900so i would take it to 7800 but do you think i should stay at 7800. with the todas...</TD></TR></TABLE>
im calling bs on this post, because you ask if they work with the stock valve train, then the same day you posted that you took it to the dyno and that you got them for $100
right, even if your friend was on crack and dying i dont think he would sell them for only $100
Old Aug 4, 2005 | 03:19 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: TODA? (built562)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by built562 &raquo;</TD></TR><TR><TD CLASS="quote">
right, even if your friend was on crack and dying i dont think he would sell them for only $100</TD></TR></TABLE>LMAO, you never know with crack heads...
Old Aug 4, 2005 | 04:23 PM
Deemeetree's Avatar
Electrician
Unless you're going to dyno it, I'd say no. Pretty retarded to buy something without knowing if it will work or not.
Old Aug 4, 2005 | 05:57 PM
punx04's Avatar
sorry to be a thread jacker but should these cams even be used with stock b16 compression? or should we just stick with sk2 stage 1's or bc3's. or would the a's be fine with maybe a mugen h.g. or flat valves. does anybody have dyno's of these cams?
Old Aug 4, 2005 | 07:35 PM
Combustion Contraption's Avatar
Its the ramp rate you should really be concerned with.
Old Aug 4, 2005 | 09:02 PM
b16brandon's Avatar
no no no
Old Aug 4, 2005 | 10:39 PM
punx04's Avatar
i dont follow...why should i be worried about the ramp rate?
Old Aug 5, 2005 | 01:57 AM
jdmsi1320's Avatar
with the toda spec a cams use a type r valve train if you go lower in stage then upgrade to a aftermarket valve train
Old Aug 5, 2005 | 02:18 AM
supaman111's Avatar
Not really but you can use Type R valve train which will be ok.
Old Aug 5, 2005 | 09:06 AM
ASpecProducts's Avatar
TODA says to use Type R Valve springs.
They make the Camshafts, so they know there own products!
Old Aug 5, 2005 | 09:14 AM
punx04's Avatar
toda says use type R valvetrain up to 8400 but i believe the cams make power up to 8800? is it worth it to spend a lil extra cash to get those 400 extra rpms?
Old Aug 5, 2005 | 09:47 AM
B--RYAN's Avatar
bump for toda
N1 Andy
Oct 17, 2008 11:34 PM
.Mason
Apr 11, 2008 08:53 AM
RicTRD
Mar 16, 2005 01:43 PM
rev210k
Jun 30, 2004 12:24 AM
93solsigsr
Apr 29, 2003 06:34 PM
