A/C problem
Old Jul 26, 2005 | 02:00 PM
Fastrax203's Avatar
Default A/C problem
I just changed the compressor on my '93 Civic EX, i recharged the system and now the compressor keeps short cycling...the clutch engages and then immediately disengages...i haven't figured out why this is happening...the a/c system does NOT get cold at all...it's almost as if once the compressor hits a certain amount of pressure in the lines it cuts off the compressor...and it squeels really loud when the clutch engages, but it has a new belt and the tension is perfect...help me out guys...should i just return it and try a different compressor?
Old Jul 26, 2005 | 11:22 PM
kkim's Avatar
Default Re: A/C problem (Fastrax203)
how did you recharge the system? what is your low side pressure reading?
Old Jul 26, 2005 | 11:56 PM
Milano_EH3's Avatar
I had a similar problem on my hatch. The problem was a bad compressor clutch. Did you JUST change the compressor (i.e. are you using the old clutch set)? Or did you get an entirely new assembly?
Old Jul 27, 2005 | 06:27 AM
Fastrax203's Avatar
entirely new assembly...i recharged it using the machine we have here @ the dealership...i bought the compressor from advanced auto...haha i think it has a bad pressure switch...gonna get one from a bap geon
EcRzFinesT
Honda Civic (2001 - 2005)
19
Aug 11, 2015 08:20 AM
d-ramey
Acura TSX
May 23, 2014 05:47 PM
elia1987
Apr 15, 2013 05:47 PM
Rooftop-Special
12
Jul 12, 2010 01:26 PM
itzyaboyzeem03
Jul 27, 2009 12:02 PM
