GT28RS: What amounts of PSi can it push, how do you control the internal wastegate?
Old Jul 26, 2005 | 01:33 PM
B_Something's Avatar
Default GT28RS: What amounts of PSi can it push, how do you control the internal wastegate?
I really hate even ask this, but I have been looking alot. I have a 95 coupe with an LS swap with a Turbonetics T3/T4 currently. I would really like to get the disco potato, just due to the great streetability it seems to bring.
Any links or help from gurus will be greatly appreciated.
Old Jul 26, 2005 | 01:48 PM
RacerXI's Avatar
Default Re: GT28RS: What amounts of PSi can it push, how do you control the internal wastegate? (B_Somethin
If you're running a t3/t4, i'd opt for the atpturbo.com gt28rs "t3/t4" drop-in option. That is unless you plan to swap manifolds & downpipes. You could block of your external gate and run the internal. An internal gate is no more complicated than an external being that it needs a vaccuum source to open up. You'd need to ask which size spring your internal gate is though.
Old Jul 26, 2005 | 02:05 PM
igo4bmx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RacerXI &raquo;</TD></TR><TR><TD CLASS="quote">If you're running a t3/t4, i'd opt for the atpturbo.com gt28rs "t3/t4" drop-in option. That is unless you plan to swap manifolds & downpipes. You could block of your external gate and run the internal. An internal gate is no more complicated than an external being that it needs a vaccuum source to open up. You'd need to ask which size spring your internal gate is though. </TD></TR></TABLE>
the only worry i have with an internal wg on the gt28rs is, you cannot clock the turbo without affect the internal wg positioning.
Old Jul 27, 2005 | 09:05 AM
Thanks for the input guys, anyone else?
HamiltonRex
Dec 24, 2008 07:39 PM
jojowasha
Jun 10, 2008 08:08 PM
ebydrc
Oct 9, 2007 09:22 AM
elpiar
Jul 16, 2005 05:08 AM
freakie
Jul 12, 2005 10:59 AM
