94-97 boosted accords??
Old Jul 26, 2005 | 01:24 PM
91 VTEC akkord's Avatar
Default 94-97 boosted accords??
anyone here running a boosted 94-97 sohc vtec accord engine? preping myne and have some questions.
Old Jul 26, 2005 | 01:30 PM
JDM4DRACCORD's Avatar
do a search then broham
Old Jul 26, 2005 | 01:42 PM
Default Re: (JDM4DRACCORD)
donts quiet understand your reply, not being a jerk, just dont understand.
Old Jul 26, 2005 | 01:46 PM
carolinaACCORD's Avatar
Default Re: (91 VTEC akkord)
What are your questions?
Old Jul 26, 2005 | 01:59 PM
Default Re: (carolinaACCORD)
well here it go's...
i have a t3 and all exhuast is allready been taken care of. having a custom set up made through a local shop. i also have DSM 450cc injectors. and a nice little intercooler. i know all about the pluming for the oil and coolant lines. but where do i get the "t" fitting that go's into the back of the block where the oil dummy guage is plugged in. from what i've seen you just unthread the oil sensor, screw in the "t" fitting and then the stock sensor just plugs into the end of the "t" fitting. and i know how to do the return into the oil pan. but to i have to change anything on my ECU. i'm only running a 8lbs. boost. and where do i get the resistors that i have to splice into the "common" wire on the injectors. changes the ohm rating or somthing. anything else im missing, let me know. thanks
Old Jul 26, 2005 | 04:40 PM
poid's Avatar
firstly, accords have a resistor box standard so you dont need to worry about that bit.
If you are running DSM 450's, what kind of fuel management are you running? If you are just thinking about running the DSM's and stock ECU with nothing else you are gonna have a world of trouble
Accordian47
Dec 22, 2015 03:37 PM
dohc_profile
Jul 23, 2006 07:24 PM
crazychrisjdmcrx
May 19, 2005 09:13 PM
technine
Jun 2, 2003 07:30 PM
95IntegraGSRAZ
Apr 23, 2002 02:59 AM
