RWD Del Sol: H22 turbo
Old Jul 26, 2005 | 10:44 AM
WhiteSol's Avatar
Default RWD Del Sol: H22 turbo
I've been browsing here for quite a while, just thought I would share my Hybrid thread with those of the EG community that don't venture over there often
https://honda-tech.com/zerothread?id=1266033
Thanks for looking!
-Scott
Old Jul 26, 2005 | 10:54 AM
JDM-EJ1's Avatar
Default Re: RWD Del Sol: H22 turbo (WhiteSol)
Crazy.
Old Jul 26, 2005 | 11:00 AM
92HatchB16's Avatar
Nice
JDM-EJ1's Avatar
Default Re: RWD Del Sol: H22 turbo (92HatchB16)
I'm really interested to see how this car turns out, I've seen a B series into an Integra but never an H series into the a Sol.
Old Jul 26, 2005 | 11:03 AM
JimmyAtlantis's Avatar
Default Re: RWD Del Sol: H22 turbo (JDM-EJ1)
That's sweet, but you better corner weight the car properly so you can turn well.
Old Jul 26, 2005 | 11:04 AM
JDM-EJ1's Avatar
This may be a stupid question.. But how is the exhaust going to work? Obviously the exhaust manifold is pointed towards the front of the car, are you going to get it bent around and out through the rear?
Default Re: RWD Del Sol: H22 turbo (JimmyAtlantis)
And what are you using for springs to support that extra weight in the back?
Old Jul 26, 2005 | 11:05 AM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimmyAtlantis &raquo;</TD></TR><TR><TD CLASS="quote">And what are you using for springs to support that extra weight in the back?</TD></TR></TABLE>
Yeah, I'm curious about that as well. Hopefully he'll post up and answer all of our questions. This is going to be a great project.
Old Jul 26, 2005 | 11:14 AM
WhiteSol's Avatar
Ground control Coilovers on all four corners. 12kg/mm rear, and 8kg/mm at the front
Thanks for your comments! The build is going well, I just wish there were more hours in a day!
Old Jul 26, 2005 | 11:15 AM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteSol &raquo;</TD></TR><TR><TD CLASS="quote">Ground control Coilovers on all four corners. 12kg/mm rear, and 8kg/mm at the front
Thanks for your comments! The build is going well, I just wish there were more hours in a day!</TD></TR></TABLE>
How about the exhaust how are you going to do that?
Old Jul 26, 2005 | 11:18 AM
red-eg6's Avatar
PUT ONE IN THE FRONT
Old Jul 26, 2005 | 11:20 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: RWD Del Sol: H22 turbo (red-eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red-eg6 &raquo;</TD></TR><TR><TD CLASS="quote">PUT ONE IN THE FRONT </TD></TR></TABLE>lmao
Old Jul 26, 2005 | 11:21 AM
Stoich EG2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">This may be a stupid question.. But how is the exhaust going to work? Obviously the exhaust manifold is pointed towards the front of the car, are you going to get it bent around and out through the rear?</TD></TR></TABLE>
If you noticed, he did not flip the engine around 180 degrees when he put it in the rear. It was just moved back. The exhaust will work the same except it will be shorter obviously.
Old Jul 26, 2005 | 11:22 AM
Luserkid's Avatar
This has been done before but not the way you did it. You basically took the front end of the civic and put it in the back to mount the motor, very clever.
The guy that did this before on this site made custom everything. I bet his kicking himself now for not thinking of this, lol. Still very nice both of you. Why is it always H22's though? ehh
Old Jul 26, 2005 | 11:23 AM
JDM-EJ1's Avatar
Default Re: RWD Del Sol: H22 turbo (ADVAN EG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ADVAN EG2 &raquo;</TD></TR><TR><TD CLASS="quote">
If you noticed, he did not flip the engine around 180 degrees when he put it in the rear. It was just moved back. The exhaust will work the same except it will be shorter obviously.</TD></TR></TABLE>
That's what I was thinking. Thanks for clearing that up.
Old Jul 26, 2005 | 11:24 AM
Del Sol SiR's Avatar
Scott this beast is marvelous!
Old Jul 26, 2005 | 11:25 AM
JDM-EJ1's Avatar
Default Re: (DELSOLEMITE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DELSOLEMITE &raquo;</TD></TR><TR><TD CLASS="quote">Scott this beast is marvelous!</TD></TR></TABLE>
x2.
I'm really eager to see the timeslips on this beat.
Old Jul 26, 2005 | 11:26 AM
litterbox's Avatar
Your skill level and ingenuity is what I strive to achieve.
green-'s Avatar
Default Re: RWD Del Sol: H22 turbo (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">This has been done before but not the way you did it. You basically took the front end of the civic and put it in the back to mount the motor, very clever.
The guy that did this before on this site made custom everything. I bet his kicking himself now for not thinking of this, lol. Still very nice both of you. Why is it always H22's though? ehh </TD></TR></TABLE>
I thought I remember seeing a video of somebody else who did this.
for ingenuity.
Old Jul 26, 2005 | 11:27 AM
ay_dawg's Avatar
That's sick. Keep us updated
Old Jul 26, 2005 | 11:28 AM
WhiteSol's Avatar
How about the exhaust how are you going to do that?</TD></TR></TABLE>
Exhaust is going to be a bit tricky, I have over foot of room to work with between the engine and the frame. More than likely it will be side exit exhaust.
Thanks for the questions!
Like this?
Old Jul 26, 2005 | 11:30 AM
JDM-EJ1's Avatar
Default Re: (litterbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">Your skill level and ingenuity is what I strive to achieve.</TD></TR></TABLE>
Dude, Andy.. You're swapping a K20 into an EH2, you're lookin' good to me.
Old Jul 26, 2005 | 11:32 AM
JDM-EJ1's Avatar
That's what I was thinking because to me it seems there would be a clearance issue with the frame.
Old Jul 26, 2005 | 12:13 PM
WhiteSol's Avatar
Thanks for the compliments!
Cody's (Tinker219) Del Sol is now owned by Dan (rawkus), and it was very much a prototype. I remember when researching rear engine swaps coming across his project and wondering why he didnt use the entire front clip; but with most projects I've found out that we use what he have and what we know. Tubing turned out great for him, and I bet it is quite a bit stronger than unibody.
Why H22s? Personal preference for me. I've owned preludes since I was 15 and was impressed with the H series motors.
Old Jul 26, 2005 | 12:29 PM
BlueIntegraBoy's Avatar
I love your project, I've been following it for a long time.
