Suspension & Brakes Theory, alignment, spring rates....
Rear control arm bushings shot, Help Please
Old Jul 26, 2005 | 08:27 AM
MrPink69's Avatar
Default Rear control arm bushings shot, Help Please
- 1990 Honda Civic Hatch DX
Im in the middle of certifying my car and found my main rear control arm bushing is shot. Can these bushings be replaced or do i need a complete arm?
thanx
Old Jul 26, 2005 | 09:17 AM
crxgator's Avatar
Default Re: Rear control arm bushings shot, Help Please (MrPink69)
you can replace the bushings if you want to buy individual bushings and waste your time installing them...or buy a whole new LCA from honda for about 60 bucks...
Old Jul 26, 2005 | 10:32 AM
Tyson's Avatar
are you talking about the trailing arm bushing? the 3" diameter bushing? or the lower control arm that the shock mounts to?
Old Jul 26, 2005 | 01:31 PM
MrPink69's Avatar
Default Re: Rear control arm bushings shot, Help Please (Tyson)
Yeah the big one, 3" or so. I just called the dealership and they said $300 a side for the whole arm and they said you cant buy bushing, only the arm!! The reason im still posting is because I don't trust dealerships, they're always looking to make lil $$$
I wonder what the odds are of finding one in decent shape from the scrap yard?
OH, I just started taking the arm out a little while ago and i already broke 2 bolts and the rest are seized so im in the middle of cutting out my floor,the double layer where the threaded peices are. Guess im torching THERE SHOULD SOME DAMN ACCESS HOLES FOR THOSE DAMMIT This is the main thing I hate about these import cars
Old Jul 26, 2005 | 02:05 PM
Tyson's Avatar
you can get the trailing arm bushing individually, but most dealers dont know that and its probably not in their database. it was a change made later on, along with a Technical service bulletin.
go here for some write up about installing these properly. its for integra trailing arms which have larger diameter bushings, but theres still the right info for civics.
http://www.performanceforum.co....html
Modified by Tyson at 1:08 PM 7/28/2005
Old Jul 26, 2005 | 08:44 PM
MrPink69's Avatar
That will help a lot, thanx
Old Jul 27, 2005 | 06:10 AM
Wes V's Avatar
I hate to be picky on the wording that Tyson used, but;
The "integra" bushings are not "wider", they are larger in diameter.
I just don't want anybody to get confused.
Wes
Old Jul 28, 2005 | 12:09 PM
Tyson's Avatar
Default Re: Rear control arm bushings shot, Help Please (Wes V)
pick pick
Old Aug 5, 2005 | 07:03 AM
98civicEX's Avatar
http://cgi.ebay.com/ebaymotors...46248
This is what you need!, They worked great in my car. Here's a link on how to install them at home:
http://honda.hybrids.jp/tech/howtos/bushings.shtml
Good luck.
AZ-Accord
Jan 9, 2013 05:23 PM
kasperxtcy
Suspension & Brakes
Mar 24, 2010 09:14 AM
95JDM
Sep 15, 2008 03:22 PM
G3NR8
Apr 3, 2004 04:57 PM
Jdm93civic
Aug 24, 2003 10:47 AM
