Bad CV joints or wheel bearings?
Old Jul 26, 2005 | 07:25 AM
pdc125's Avatar
Default Bad CV joints or wheel bearings?
I have a 93 LS, and for awhile it has made a knocking noise in the right front when I turn left. Now it has started making noise when turning in both directions, and has gotten alot louder. The boots on the cv joints seem fine and aren't leaking at all, and there isn't any play in the wheel bearings when I yank the wheels back and forth. Is there any other trouble shooting I can do to pinpoint this problem? It's getting boosted in 2 weeks so I'd like to have it solved before that to prevent extra headaches.
Old Jul 26, 2005 | 10:20 AM
solareclipseauto's Avatar
Default Re: Bad CV joints or wheel bearings? (pdc125)
the joints may have gone dry, try and regrease them if there not to bad, if they are replace your axles
Old Jul 26, 2005 | 10:56 AM
JDM-EJ1's Avatar
Default Re: Bad CV joints or wheel bearings? (solareclipseauto)
If it's the CV joints, go into an empty parking lot and throw it in reverse and drive with the door open and listen for a *click* noise, that will indicate if your CV joints are going.
Old Jul 26, 2005 | 06:16 PM
t_lager's Avatar
Default Re: Bad CV joints or wheel bearings? (JDM-EJ1)
My bet is the cv joints, especially with you saying it happens when you turn..... bad wheel bearings usually have a humming sound when you drive
Old Jul 27, 2005 | 07:21 AM
pdc125's Avatar
Default Re: Bad CV joints or wheel bearings? (t_lager)
Thanks alot guys. I was almos positive that it was the cv joints, but I recently had somebody trying to convince me that it was a wheel bearing. I'll do some more troubleshooting and see what I come up with.
Old Jul 27, 2005 | 07:27 AM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdc125 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks alot guys. I was almos positive that it was the cv joints, but I recently had somebody trying to convince me that it was a wheel bearing. I'll do some more troubleshooting and see what I come up with.</TD></TR></TABLE>
Yeah, like what I suggested that is a really good way to find out if it's the CV joints.
jkalex05
Nov 23, 2009 06:52 PM
Secret Chimp
Feb 9, 2008 01:27 PM
dRuNkEnMoNkEy97
Sep 27, 2006 08:56 PM
jdmazm
Apr 28, 2005 07:57 PM
yusoslo
13
May 26, 2004 03:09 PM
