climate control not working
my 97 coupe climate control doesnt work. The temperature slider slides freely but doesnt change the temp of the air coming out. I put my hand through the radio hole and found a wire inside of a black housing. Is that suppose to be connected to the back of my climate control??? If so, how do I get behind there? What's the easiest way to connect it? Thanks for your help
Try checking for the steel cable that is connected to the temprature slider. It should connect at the passenger side floor up under the dash, try feeling for a loose steel cable.
