my new setup what compression will i be running around??
Old Jul 26, 2005 | 05:38 AM
veilsides2000's Avatar
Default my new setup what compression will i be running around??
What going on guys my current mods are as follows
MODS:
Aem cold air intake
skunk2 intake manifold
removed P.S
removed A.C
fluidyne radiator
clutchmasters stage 3 clutch
skunk2 p28 chipped ecu
test pipe w stock muffler
ground control coilovers
98 front end conversion
ls transmission (used to be turbo)
Mods to come:
:Civic type r pistons
:Arp rod bolts
mni power valve train (retainers,springs,valves)
(still waiting on them)
:Skunk2 stage2 cams
:skunk2 adjustable cam gears
:jdm dc itr 4-1 header
:skunk2 megapower exhaust
:carsound hi flo cat
:hondata s200
:brand new clutchmasters stage3 clutch
:fidanza 7.5lb flywheel.
what you guys think??? is this a strong setup??? and what will the compression ratio be?? about
Default Re: my new setup what compression will i be running around?? (veilsides2000)
and i'm also getting a gs-r transmission
Old Jul 26, 2005 | 12:04 PM
no one with a compression ratio??
Old Jul 26, 2005 | 12:10 PM
ALLMOTA92EG's Avatar
What kind of block and head?
Old Jul 26, 2005 | 12:28 PM
Default Re: (jdm92civichb)
its a b18c1 engine. gs-r block, gs-r head
veilsides2000
Feb 25, 2006 04:52 PM
veilsides2000
10
Feb 25, 2006 01:52 PM
veilsides2000
Feb 23, 2006 03:52 PM
veilsides2000
Jul 28, 2005 10:34 PM
sleepycivix
Dec 18, 2002 08:30 PM
