Cutting valve cover?
Old Jul 26, 2005 | 05:24 AM
BigC-ivic's Avatar
Default Cutting valve cover?
Any advice on cutting a valve cover? (I want to expose my new buddy club cam gears for tuning and the Bling factor)
I plan on taking mine off to bring to a machine shop but I was wondering about the seal that goes around the cover. Do I have to cut that as well?
Old Jul 26, 2005 | 05:43 AM
B18ls*RAYON's Avatar
Default Re: Cutting valve cover? (BigC-ivic)
I would like to know too.
Old Jul 26, 2005 | 05:58 AM
JDM-EJ1's Avatar
Default Re: Cutting valve cover? (B18ls)
I'm sorry, but why would you be cutting it and where?
Old Jul 26, 2005 | 06:03 AM
BigC-ivic's Avatar
Default Re: Cutting valve cover? (JDM-EJ1)
cutting the end off, to expose the cam gears
(that way if you ever need to readjust or tune again it is simple)
Old Jul 26, 2005 | 06:08 AM
mastamind's Avatar
http://www.team-integra.net/se...D=677
Are you planning on doing a mooncut or not?
Old Jul 26, 2005 | 06:13 AM
BigC-ivic's Avatar
Default Re: (mastamind)
thanks
it looks like the valve cover gasket only covers the part of the head up to the gam gears... so it shouldn't have to be cut!
is it really a good idea to take the entire timing belt cover off (even the bottom bart)?
Old Jul 26, 2005 | 06:14 AM
BigC-ivic's Avatar
Default Re: (BigC-ivic)
I always thought people chopped the whole end piece off?
Old Jul 26, 2005 | 06:42 AM
ExVtec's Avatar
I used a dremel to score the edges where I wanted cut, then a pair of plyers and it snapped right off....
Outlined with a marker and then cut...
Voila...mooncut...
Btw...the valve cover gasket does not need to be touched....
Old Jul 26, 2005 | 06:53 AM
BigC-ivic's Avatar
Default Re: Cutting valve cover? (ExVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExVtec &raquo;</TD></TR><TR><TD CLASS="quote">I used a dremel to score the edges where I wanted cut, then a pair of plyers and it snapped right off....
Voila...mooncut...
cool
did you take off the bottom of the belt cover?
Old Jul 26, 2005 | 07:37 AM
Racermech's Avatar
I have seen people chop off the entire end, but then you expose the bet to everything, and if you are working on the car while the engine is running you have one more risk. I like the "moon" cut out, it looks very clean
Old Aug 3, 2005 | 01:18 PM
ExVtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigC-ivic &raquo;</TD></TR><TR><TD CLASS="quote">cool
did you take off the bottom of the belt cover?</TD></TR></TABLE>
Moon cut
Old Aug 3, 2005 | 01:36 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigC-ivic &raquo;</TD></TR><TR><TD CLASS="quote">is it really a good idea to take the entire timing belt cover off (even the bottom bart)?</TD></TR></TABLE>
In my opinion, it's not a good idea to cut the valve cover at all, but if you're absolutely set on doing it, I'd suggest removing as little of it as possible.
Old Aug 3, 2005 | 03:05 PM
Sifu's Avatar
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
In my opinion, it's not a good idea to cut the valve cover at all, but if you're absolutely set on doing it, I'd suggest removing as little of it as possible.</TD></TR></TABLE>
Yup, just do the "mooncut" if u must
Old Aug 3, 2005 | 03:18 PM
Irish Integra's Avatar
I agree totally, what if a stone or some debris were to hop up off the road and get caught up in the belt? Bang, stop, bendy valves, head off + lotsa money spent.
Old Aug 3, 2005 | 05:26 PM
GrayT's Avatar
Default Re: (Irish Integra)
I have 2 valve covers. One is a moon cut and one is the stock one. One for tuning, one for driving.
Old Aug 3, 2005 | 06:38 PM
Padawan's Avatar
Darth ModerVader
Default Re: (GrayT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GrayT &raquo;</TD></TR><TR><TD CLASS="quote">I have 2 valve covers. One is a moon cut and one is the stock one. One for tuning, one for driving. </TD></TR></TABLE>
Exactly what I would recommend.
Old Aug 3, 2005 | 08:47 PM
riceball777's Avatar
heres mine with the new str cam gears
Modified by riceball777 at 5:58 AM 8/4/2005
Modified by riceball777 at 8:28 AM 8/5/2005
b16bri
Paint and Body
Jan 12, 2008 07:24 PM
Weel
Mar 17, 2004 05:01 PM
JeremyL
Apr 16, 2003 10:10 PM
arw321
Jul 18, 2002 03:40 AM
Scary1109
Dec 15, 2001 10:00 AM
