slight ticking after valve adjustment
Old Jul 25, 2005 | 11:15 PM
redpeppers's Avatar
Default slight ticking after valve adjustment
if there is slight ticking after valve adjustment......do u suggestion i recheck valve clearance?
Old Jul 25, 2005 | 11:27 PM
dc2legend's Avatar
Default Re: slight ticking after valve adjustment (redpeppers)
Yes, sounds like maybe you might have not adjusted one correct.
Old Jul 25, 2005 | 11:31 PM
redpeppers's Avatar
Default Re: slight ticking after valve adjustment (dc2legend)
cool thanks
Old Jul 26, 2005 | 11:21 AM
redpeppers's Avatar
so would i need to tightn of loose to remove ticking?
Old Jul 26, 2005 | 12:33 PM
95 integra's Avatar
Tighten to get rid of it....unless its a worn LMA.
Old Jul 26, 2005 | 02:33 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
One of them is probably too loose. Go back and check them all again (engine cold of course).
First time I did a valve adjustment, same thing happened to me, only it was so bad my car sounded like a diesel engine. Checked all the clearances again and found one exhaust valve to have about .030" clearance. Tightened that down to spec and all was good.
trevorlehr88
May 12, 2019 04:30 AM
supersize
Jul 26, 2010 11:50 PM
Robotoyaki
Jan 1, 2010 02:10 PM
CRXSi90
Jun 23, 2009 07:19 PM
mattymatt
Aug 4, 2001 04:39 PM
