integra fuel injector and ecu question
Old Jul 25, 2005 | 08:02 PM
projektvtec's Avatar
Default integra fuel injector and ecu question
i have an ls-vtec and i was wondering if i put larger injectors in it , do i have to let the ecu know or do anything with the ecu?? i was also wondering if i should put larger injectors in it if i was eventually going to hook up NOS to the engine.
Old Jul 25, 2005 | 09:13 PM
5litereater's Avatar
Default Re: integra fuel injector and ecu question (projektvtec)
yes. the computer will not compensate for the extra fuel. you would need a socket soldered into your ecu and have somoen build you a basemap. but in order for any of this to allow you to make more power, you would need some dyno time...
Old Jul 25, 2005 | 10:25 PM
pubestripe's Avatar
Default Re: integra fuel injector and ecu question (5litereater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5litereater &raquo;</TD></TR><TR><TD CLASS="quote">yes. the computer will not compensate for the extra fuel. you would need a socket soldered into your ecu and have somoen build you a basemap. but in order for any of this to allow you to make more power, you would need some dyno time...</TD></TR></TABLE>
yep. plan on paying for a good tune!!!
Violentpanda
Sep 11, 2018 02:57 PM
balbowskie
Jun 28, 2012 01:13 PM
98vtec
Mar 18, 2008 07:36 PM
