How would a bad/failing FPR show itself?
test the fpr...
attach a fuel pressure gauge to the service port on the fuel filter, disconnect the vacum hose from the regulator and check the reading. did the pressure rise when u disconnected the hose? you should have around 35-41 psi with it disconnected. if the pressure did not rise check to see if the pressure rises when you pinch the return line slightly. if the pressure does not rise you got yourself a bad regulator.
I dont have a gauge handy yet
My car seems to be bogging and running rich could a busted fpr be dumping to much fuel?
Modified by Stoich at 3:34 PM 7/26/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stoich »</TD></TR><TR><TD CLASS="quote">I dont have a gauge handy yet
Modified by Stoich at 3:34 PM 7/26/2005</TD></TR></TABLE>
I've heard that a FPR going out could cause this, but it could be a number of things also...try going to Advance Auto or some other parts store...sometimes they let you borrow tools - they may have a gauge.
4gencivicef9
11
Aug 19, 2007 01:52 PM
full Circling
Jul 13, 2005 01:31 PM
kun3racer
Sep 27, 2004 08:21 PM
