14" Mugens over GSR brakes?
Does anyone know if 14" Mugen wheels will fit over GSR brakes? I'm looking at CF-48s and MR5s. I know some 14" wheels will fit and some won't so some first hand experience would be appreciated.
yea the gsr brakes should fit fine with 14s, i do know that certain 14's such as hx will have to be modified a bit to fit the calipers correctly...why not jus get 15s and not have a big problem at all and 15s cant be much more expensive than the 14s....just my 2 cents
The real question is what 14 inch wheels fit over 11" Brakes? I heard somewhere, that volk makes a 14 inch wheel that fits over ITR brakes...any truth to this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sockvtec »</TD></TR><TR><TD CLASS="quote">why not jus get 15s and not have a big problem at all and 15s cant be much more expensive than the 14s</TD></TR></TABLE>
Yeah for a couple different reasons I'd kind of rather go with 14s, but if anything at least knowing that they fit would give me the most options.
integra brakes (not gsr...) will fit under 14" fine, as long as the spokes to not connect with the caliper (check offset - I wouldnt want 38).
Worst case, you need to run a 5mm spacer
Ive seen type r brakes behind 14" too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ko »</TD></TR><TR><TD CLASS="quote">gsr brake setup can not fit stock 14" steelies. at least not on mine.</TD></TR></TABLE>
Where do they not fit? Is it an offset issue?
We've gone over this many times.
94-01 Integras come with 14" rims, so YES GSR brakes will clear a 14" rim. Check its offset if you are using an aftermarket rim.
YES the 11.1" rotors with ITR calipers take a 15" rim and there IS a 14" rim that will clear them, it is a Volk rim, i believe 6 spoke design and its not cheap.
Look, the 96 civic EX brakes can fit under a 14" steelie. The 99-00 Si has the SAME brakes and I do mean identical, thus can take a 14" steelie. The 96 GSR has the SAME brakes EXCEPT the caliper piston is larger and thus are more powerful. The pads are similar and the caliper is not so much larger that it takes a 15". A GSR will allow 14" steelies over it.
