OIL PAN HELP: QUICKLY
Old Jul 25, 2005 | 07:30 PM
ericjackson's Avatar
Default OIL PAN HELP: QUICKLY
the threads in my oil drain plug are stripped, its leaking oil like a champ, and i have to go out of town in 3 days.i have to work every day until then. what are my options? can you get an oversized bolt to put in there, is it some kind of special bolt? is it easy to rethread? thanks to all help, and any help at all would be appreciated
btw, its a 98 accord 4cyl coupe, thanks
Old Jul 25, 2005 | 07:36 PM
deserthonda's Avatar
Default Re: OIL PAN HELP: QUICKLY (ericjackson)
remove pan plug, they sell inserts u need 14.5 mm drill pan, put insert in and new plug it works like a champ i have done too many to keep count
Old Jul 25, 2005 | 07:40 PM
Default Re: OIL PAN HELP: QUICKLY (deserthonda)
where would they sell something like that?
Old Jul 25, 2005 | 08:08 PM
i got the kit from MATCO tools, i dont know wether autozone , checker, pep boys napa sell it .. .sears?????
Old Jul 26, 2005 | 03:17 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ericjackson &raquo;</TD></TR><TR><TD CLASS="quote">can you get an oversized bolt to put in there,</TD></TR></TABLE>
Yep, oversized drain plugs are great. Just crank them in, no drilling or tapping needed.
Old Jul 26, 2005 | 06:12 AM
Default Re: OIL PAN HELP: QUICKLY (Chiovnidca)
yo Chio those things dont last long at all and after a few oil changes they leak again ,,if you want to fix it properly and not worry about a leak everytime you change oil you got to put an insert in fix it right the first time and forget about it
Old Jul 26, 2005 | 02:26 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote"> yo Chio those things dont last long at all and after a few oil changes they leak again ,,if you want to fix it properly and not worry about a leak everytime you change oil you got to put an insert in fix it right the first time and forget about it</TD></TR></TABLE>
Never had a problem with the oversize plugs, inserts are another story though. They always get stuck to the plug.
Old Jul 26, 2005 | 03:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Never had a problem with the oversize plugs, inserts are another story though. They always get stuck to the plug.</TD></TR></TABLE>
not if you countersink them ..i have install a **** load and never had 1 come aprt with plug ..like i said there is a kit that makes the job real good you do it once and forget kit comes with drill bit , tap, inserts , countersinker tool and locktite to put on insert threads before you install it
Old Jul 26, 2005 | 03:30 PM
well, today i went with an oversized plug, i dont know what the threads are gonna do, so next time i do an oil change, i may have a backup oil pan. but thanks everyone, i was freakin out
Old Jul 26, 2005 | 09:03 PM
Default Re: (ericjackson)
do not waste the money on a oil pan just put an insert in so much cheaper and they last ,,,,,,,,,,,,, have a shop do it ..
Old Jul 27, 2005 | 03:11 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ericjackson &raquo;</TD></TR><TR><TD CLASS="quote">well, today i went with an oversized plug, i dont know what the threads are gonna do, </TD></TR></TABLE>
Dont overtighten it and it should be ok.
Old Aug 2, 2005 | 10:52 PM
CB7VTEC's Avatar
I've been using an OS drain bolt with OEM drain bolt crush washers for about 4 years now, no leaks. You have to thread the washer onto the bigger plug carefully without damaging it, but it fits. Most of the times I've seen OS drain bolts leak is when people neglect to use some sort of crush washer.
supadupafast
Aug 11, 2013 09:57 AM
gasha1
Jan 9, 2009 05:55 AM
Spithead051
Dec 17, 2008 03:53 PM
budget
May 24, 2005 07:44 AM
JMod
Dec 8, 2003 05:37 PM
