Few projects I been working on
Stock air box turned ghetto icebox-
New grounds-
4 gauge wire from engine to radiator support
Trans to chassis 4 gauge ground, that also travels up to the battery. Starter and dizzy grounds will also be added at this point.
Grounds at battery, main chassis ground is 0 gauge and the 4 gauge goes down to the chassis\trans ground location-
Engine harness plugs mounted further down the strut tower in order for the password JDM bar to fit. This was done by bending the upper tab on the mounting bracket for the plugs, removing the alt wire tie down and bolting back up to the original bolt hole using the bent up tab. Mounts the plugs perfectly below the top of the tower claering the bar. Hope that was all understandable.
New grounds-
How much did the grounds cost you total? Sounds like they do work as far as I've heard.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">Looks good man. I'm also trying to do the DIY icebox as well.</TD></TR></TABLE>
That sounds interesting. Any write ups? (I'm new to EGs.... bare with me here
edit- found it
)edit- found it
10 feet of 4 gauge 10 bucks- stinger pro audio wire
1 foot of 0 gauge- 2-3 bucks stinger pro audio
50 gold plated 4 gauge connectors 25.00
Battery terminal- 30.00 tsunami audio(can find cheaper on Ebay)
2 0 gauge platinum connectors- 3 bucks
Next is the starter power wire and alt wires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std »</TD></TR><TR><TD CLASS="quote">How much did the grounds cost you total? Sounds like they do work as far as I've heard.
edit- found it
It's really simple to do it, if you just look an an actual Comptech Icebox and then your OEM airbox you can see how you would do it. If you need further clarification, PM me.
)edit- found it
</TD></TR></TABLE>It's really simple to do it, if you just look an an actual Comptech Icebox and then your OEM airbox you can see how you would do it. If you need further clarification, PM me.
ahhh man, as if it was that simple...i created my own CAI with heat ducting, duct elbows and a RACTIVE filter.....never even thaught of cutting the styock piping at the resonater
92integraVTECgsr
Feb 22, 2018 08:33 AM
91(si)hatchey
Jul 29, 2009 08:16 AM
