Can I ditch the spring bolts at the axle back?
Old Jul 25, 2005 | 06:02 PM
GetawayInMoscow's Avatar
Default Can I ditch the spring bolts at the axle back?
Well Im done installing my megan racing exhaust and high flow cat. I started the car up and checked for leaks. Everything is fine except for the axle back portion of the exhaust. I used the stock spring bolts in there and it just won't tighten the wa y i think it's supposed to. The bottom part of where the b-pipe and axle back meet are flush but the top part has a 5mm gap I would say.
I've tried tightening the hell out of the spring bolts but it didn't really do much for me. So I think if I put in normal bolts I can get it to sit flush all around.
Has this happened to any of you and do you think my idea will work?
Old Jul 25, 2005 | 08:42 PM
lsvtecracer's Avatar
Default Re: Can I ditch the spring bolts at the axle back? (GetawayInMoscow)
I did not use the spring bolt on my megan catback. Just use two nuts and bolts and it's fine for me.
Old Jul 26, 2005 | 05:18 AM
egsleepercivic's Avatar
I think the spring bolts are only for the stock exhuast
jdmark1
May 7, 2017 02:53 PM
huge230
Aug 23, 2007 12:11 PM
Floored
Jul 17, 2006 07:37 AM
oemDC2
Jan 1, 2004 08:24 PM
Qwikrex
Nov 25, 2002 03:21 PM
