How low does everybodys turbo hang?
Old Jul 25, 2005 | 04:38 PM
Vp Special K's Avatar
Default How low does everybodys turbo hang?
I just installed my turbo kit ive put together and when i went to go do my oil return line, it looks like my turbo hangs very low. If its not even with the oil pan then it might actually be a tad lower. I'm having a hell of a time figuring out how to run the oil return line correctly with this ****** being so low.
Old Jul 25, 2005 | 05:30 PM
93turbo16's Avatar
Mine was like that for almost a year. I have no idea how it worked out, but I used high temp rubber to make the bends. I am not sure what you are going to do if it is hanging below the pan.
Old Jul 25, 2005 | 05:45 PM
project dc2's Avatar
Default Re: How low does everybodys turbo hang? (Vp Special K)
run a 90 degree fitting off the turbo. put clok turbo so that inlet is at 1:30
run straight line directly down to oil pan
Old Jul 25, 2005 | 06:15 PM
lucidvtec's Avatar
ya re clock ur turbo so its at a slight angle that should help a little..don't angle it too much that would be bad
freeagent
Oct 22, 2014 02:12 AM
BoostThisMS
Jan 25, 2013 08:46 PM
phaphon
Aug 7, 2012 09:10 AM
sheepey
Apr 22, 2010 09:33 AM
TheYellowDart
Mar 7, 2005 09:09 PM
