OBD-0 --> OBD-1 Pinouts - Correct?
Old Jul 25, 2005 | 04:11 PM
dr_latino999's Avatar
Default OBD-0 --> OBD-1 Pinouts - Correct?
This is what I have established so far from an MPFI OBD-0 to OBD-1 wiring harness jumper. I will figure out OBD-1 ECU to OBD-0 chassis in a bit, I.E wires that have to be run back into the engine.
<FONT SIZE="5">CORRECTIONS ARE WELCOME Update #2</FONT>
<FONT SIZE="2">KEY</FONT>
--&gt; XXXXXXXXXXXX Not Used
--&gt; ?????????????? What Goes here?
A01 - INJ #1 --&gt; A01 - INJ #1
A02 - PG1 --&gt; A23 - PG1
A03 - INJ #2 --&gt; A03 - INJ #2
A04 - PG2 --&gt; A24 - PG2
A05 - INJ #3 --&gt; A05 - INJ #3
A06 - PCS --&gt; A20 - PCS
A07 - INJ #4 --&gt; A02 - INJ #4
A08 - VTEC --&gt; A04 - VTEC ---&gt; RUN TO ENGINE BAY
A09 - NOTUSED--&gt; XXXXXXXXXXXX
A10 - NOTUSED--&gt; XXXXXXXXXXXX
A11 - IACV --&gt; A09 - IACV
A12 - FLR1 --&gt; A07 - FLR1
A13 - IGP1 --&gt; A25 - IGP1
A14 - FLR2 --&gt; ???????????? --&gt; Possible A08 on OBD-1 Side, Is this correct?
A15 - IGP2 --&gt; B01 - IGP2
A16 - GRD --&gt; A26 - LG1 --&gt; Possible B02 on OBD-1 Side, Does it make a difference?
A17 - NOTUSED--&gt; XXXXXXXXXXXX
A18 - GRD --&gt; B02 - LG2 --&gt; Possible A26 on OBD-1 Side, Does it make a difference?
B01 - VBP --&gt; D01 - VBU
B02 - NOTUSED--&gt; XXXXXXXXXXXX
B03 - ACC --&gt; A15 - ACC
B04 - FANC --&gt; A12 - FANC
B05 - VTECPRE--&gt; D16 - VTECPRE --&gt; Possible A16 on OBD-1 Side ALTERNATOR?
B06 - MIL A01 - INJ #1 --&gt; A01 - INJ #1
B05 - ALT --&gt; A16 - ALT
B06 - MIL --&gt; A13 - MIL
B07 - NOTUSED--&gt; XXXXXXXXXXXX
B08 - ACS --&gt; B05 - ACS
B09 - NOTUSED--&gt; XXXXXXXXXXXX
B10 - CYP P --&gt; B11 - CYP P
B11 - FUSEBOX--&gt; ???????????? N0T USED IN OBD-1 ?
B12 - CYP M --&gt; B12 - CYP M
B13 - FUSEBOX--&gt; ???????????? --&gt; Possible B09 on OBD-1 Side, Main Relay?
B14 - ALT --&gt; D09 - ALT
B15 - Igniti --&gt; ???????????? --&gt; Possible A21 on OBD-1 Side, ICM?
B16 - VSS --&gt; B10 - VSS ---&gt; RUN TO ENGINE BAY
B17 - Igniti --&gt; ???????????? --&gt; Possible A22 on OBD-1 Side, Ignitor Unit?
B18 - NOTUSED--&gt; XXXXXXXXXXXX
B19 - KS --&gt; D03 - KS --&gt; B-Series Motors Only!
B20 - SCS --&gt; D04 - SCS
C01 - CKP P --&gt; B15 - CKP P
C02 - CKP M --&gt; B16 - CKP M
C03 - TDC P --&gt; B13 - TDC P
C04 - TDC M --&gt; B14 - TDC M
C05 - IAT --&gt; D15 - IAT
C06 - ECT --&gt; D13 - ECT
C07 - TPS --&gt; D11 - TPS
C08 - NOTUSED--&gt; XXXXXXXXXXXX
C09 - PA --&gt; ????????????
C10 - BKSW --&gt; D02 - BKSW
C11 - MILGRND--&gt; ???????????? --&gt; Possible D17 on OBD-1 Side, MAP?
C12 - SG2 --&gt; D22 - SG2
C13 - VCC1 --&gt; D19 - VCC1
C14 - SG1 --&gt; D21 - SG1
C15 - VCC2 --&gt; D20 - VCC2
C16 - O2S --&gt; D14 - PHO2S
Modified by dr_latino999 at 8:59 PM 7/25/2005
Old Jul 25, 2005 | 04:59 PM
Default Re: OBD-0 --> OBD-1 Pinouts - Correct? (dr_latino999)
Has been updated twice, any comments?
dr_latino999
236
Mar 28, 2020 12:34 AM
efjones9
20
Dec 30, 2008 04:31 PM
lsvtec90
Nov 22, 2005 09:01 AM
hybridej7
Dec 20, 2004 07:15 AM
KevronsEG
12
Nov 18, 2002 07:57 PM
