What king of civic
Old Jul 25, 2005 | 03:55 PM
Redrumu2's Avatar
Default What kind of civic
I am new to Honda world. I am looking for a good civic to do a slow build up with. Preferabley nothing newer than 2001. What model should i get and what engine.
thanks
Old Jul 25, 2005 | 03:59 PM
philosofy1's Avatar
Default Re: What king of civic (Redrumu2)
go with a 92-95 civic, they're easy to worl on, cheap, and reliable
Jimballz21's Avatar
If you do most of your work yourself get an EX and put together a turbo kit, if you'll don't want to turbo get an Si out of the box they have much more power then the ex even with 2k in NA upgrades. But it's also expensive to upgrade a b16a and if you screw anything up with your motor or tranny it's expensive to replace where as a Y8 motor can be bought with low miles for a few hundred bucks.
But if you have a ton of money get the Si it has better styling then the Ex and is faster and the B16a is a good starting block
Old Jul 25, 2005 | 04:02 PM
Redrumu2's Avatar
Default Re: What kind of civic (Redrumu2)
How many horses does the ex deliver. Also do they take bolt ons pretty well. just tired of getting high beamed to death by minivans in my current car. so embarrising
Old Jul 25, 2005 | 04:07 PM
Earthworm Jim's Avatar
92-95 Hatchback (Si is you can find one). The motor is so low in Hp it's not worth mentioning but it has a little power after it's rolling (pay attention to the word little).
All the Civics that I've heard about are pretty good with bolt ons. The key is the build up the block
Old Jul 25, 2005 | 04:09 PM
Jimballz21's Avatar
The '96-2000 ex has 127 hp and no they really don't take to bolt ons well Put it this way I have a fully built y8 here is my mod list
jg camshaft
port and polished head
valve job
10.5:1 compression pistons
AEM CAI
4-2-1 header
test pipe
2.25 custom exhaust to Mugen Twinloop muffler
prelude injectors
p28ecu with uberdata
b18throttle body
clutchmasters flywheel and stage 2 clutch
some other **** but that's all i can think about
I beat civics with b16 swaps but loose to gsr swapped civics. So probably aroound a 35hp increase from stock for all that work
Now if you have $1500 you can put together a kick *** turbo kit, run uberdata and some dsm 450injectors and at 9psi You'll put down 200hp to the wheels tuned right. And with prober tuning and maintence should be very reliable.
Old Jul 25, 2005 | 04:10 PM
Jimballz21's Avatar
check out http://www.d-series.org for lot of help and info on D series motors. It's very easy to reliable have 200whp on a d motor check the site out everyone is very helpfull over there
Alex Marin
Honda Civic (2006 - 2015)
Oct 14, 2017 02:21 AM
s0biek
Aug 18, 2012 08:34 AM
carcrzy313
Dec 18, 2006 06:38 PM
mjames99
Nov 27, 2006 07:28 PM
03civicnigga
Jun 16, 2005 10:33 AM
